Finding eigenvalues and eigenvectors 2x2 matrix
The discussion focuses on finding eigenvalues and eigenvectors for a 2x2 matrix, specifically the matrix [[1, 1], [1, 1]]. The eigenvalues calculated are λ = 0 and λ = 2, with corresponding eigenvectors (1, -1) for λ = 0 and (1, 1) for λ = 2. Participants clarify that to find eigenvectors, one must solve the equation (A - λI)x = 0. The conversation also addresses the acceptability of different forms of eigenvectors, confirming that scalar multiples of eigenvectors are valid. Overall, the thread effectively guides users through the process of calculating eigenvalues and eigenvectors.
andrey21
Find the eigenvalues and corresponding eigenvectors of the following matrix.
1,1
1,1
Here is my attempt to find eigenvalues:
1-lambda 1
1 1-lambda
Giving me:
(Lambda)^2 -2(lambda) = 0
lambda = 0 lambda = 2
Is this correct??
Yes, this is good!
Great from there I get a little confused finding the eigenvectors. I sub the lambda values back into matrix but don't know where to go there.
lambda = 2 1-2 1
1 1-2
giving me: -1 1
1 -1
Where do I go next?
So you sub lambda into your matrix. This gives you a matrix A. Now you need to find a vector x such that Ax=0. This involves solving a system of equations. The solutions of that system should give you the eigenvectors...
Rite so I have the two following matrices from lambda values:
lambda = 2
-1, 1
1,-1
so that means -x1 + X2 = 0 AND x1 -x2 = 0 therefore x1 = x2
Am i on the rite track?
Yes, so all vectors of the form (x_1,x_1) are eigenvectors. Specifically, (1,1) is an eigenvector with eigenvalue 2...
Great so when eigenvalue = 2 eigenvector = (1,1)
When lambda = 0 I get the following matrix:
1 1
1 1
Now is this just saying x1 + x2 = 0 so x1 = -x2
eigenvector be (1,-1) ?
Yes, that is correct! (1,-1) is indeed an eigenvector of the matrix!
Fantastic thank you micromass.
Can I just ask you if this is correct?
matrix A = 2, 1
0, -1
Eigenvalues I get are:
2 and -1:
when lambda = 2:
0, 1
0, 0 So x2 = 0 therefore eigenvector is (1,0)
when Lambda = -1
3,1
0,0 n so 3x1 + x2 = 0 3x1 = -x2 so eigenvector is (-1/3, 1)
Correct?
Correct! It seems you've got the idea!
thnx micromass:)
Actually that gives you A - \lambdaI, which is different from A (unless \lambda happens to be zero).
I know what you mean, but what you really want is to find a solution of (A - \lambdaI)x = 0.
Just quick question micromass for the post 7 I've sed eigenvector is (1,-1) should it be (-1,1) or are they both acceptable?
Both are good. If x is an eigenvector and if \lambda\neq 0, then \lambda x is an eigenvector as well. In this case: (1,-1) is an eigenvector. So take \lambda=-1, then (-1,1) is an eigenvector as well!
Ah rite I see so when lambda = 0 eigenvector is (1,-1)? Its just confusing as when matrix wa:
3,1
0,0
eigenvector is (-1/3,1) ?
3,1
0,0
Assuming this is A - \lambdaI, yes, <-1/3, 1> is an eigenvector, and so are <-1, 3>, <1/3, -1>, <1, -3>, and many more. You can easily check whether a vector x is an eigenvector with associated eigenvalue \lambda by verifying that Ax = \lambdax, or equivalently, that (A - \lambdaI)x = 0.
