Finding eigenvector QM 2x2 matrix
6 replies · 2K views · last reply
Taylor_1989
I am having a issue with how my lecture has normalised the energy state in this question.
I will post my working and I will print screen his solution to the given question below, we have the same answer but I am unsure to why he has used the ratio method.
Q4. a), b), c)
Lecture slide, question 4: a qubit Hamiltonian matrix with entries 0, -Ω, -Ω, 2Ω/√3 in the {|0>, |1>} basis, with parts (a) eigenstates E+ and E-, (b) ground state eigenvector (A, B) with hint on the ratio A/B, and (c) measurement probability question.
My solution for a), b), c)
a)
$$\hat H|E> = E|E> ;[1]$$
$$\hat H|E> - E|E>=0 ;[2]$$
$$\hat H|E> - IE|E>=0; [3]$$
$$(\hat H-IE)=0 ;[4]$$
$$\begin{pmatrix}0&-\Omega \\ \:-\Omega &\frac{2\Omega }{\sqrt{3}}\end{pmatrix}-E\begin{pmatrix}1&0\\ \:0&1\end{pmatrix}=0 ;[5] $$
So expanding out and finding the determinate of the following matrix
$$\begin{pmatrix}-E&-\Omega \\ \:-\Omega &\frac{2\Omega }{\sqrt{3}}-E\end{pmatrix}=0 ; [6]$$
$$\begin{pmatrix}-E&-\Omega \\ \:-\Omega &\frac{2\Omega }{\sqrt{3}}-E\end{pmatrix}= E^2-\frac{2E\Omega }{\sqrt{3}}-\Omega ^2=0 ;[7]$$
$$\left(E-\frac{3\Omega }{\sqrt{3}}\right)\left(E+\frac{\Omega }{\sqrt{3}}\right)=0 [8]$$
So solving gives me the following for ##E_{-}## and ##E_{+}##
$$E_{-}=\frac{3\Omega }{\sqrt{3}} ; [9]$$
$$E_{+}=-\frac{\Omega }{\sqrt{3}} ; [10]$$
b) I solved the eignvector for ground state in the following way
$$\begin{pmatrix}0&-\Omega \\ -\Omega &\frac{2\Omega }{\sqrt{3}}\end{pmatrix}\begin{pmatrix}A\\ B\end{pmatrix}=-\frac{\Omega }{\sqrt{3}}\begin{pmatrix}A\\ B\end{pmatrix} ; [11] $$
$$-\Omega B= -\frac{\Omega }{\sqrt{3}}A ; [12]$$
$$-\Omega A=-\frac{3}{\sqrt{3}}B ; [13]$$
So solving for both of these give ##A=\sqrt 3## so therfore:
$$E_{-}= |0> + \sqrt 3 |1> ; [14]$$
To normalize [14] I found the normalizing constant in the following way:
$$< E_{-} | E_{-} > = 1+3=4 ; [15]$$
$$N^2 < E_{-} | E_{-} > = 1 ; [16]$$
$$N^2=\frac{1}{4}; [17]$$
$$N= \frac{1}{2}; [18]$$
$$|E_{-}> = \frac{1}{2} |0> + \frac{\sqrt 3}{2} | 1 > ; [19]$$
c) $$P(1)=\left(\frac{\sqrt{3}}{2}\right)^2=\frac{3}{4}=75\% [20]$$
Here is my lecture solution:
a)
Handwritten solution to a 2x2 eigenvalue problem: determinant of H minus E times identity equals zero, leading to E squared minus 2 root-3 E over root-3 minus Omega squared equals zero, giving E = root3 Omega or -Omega over root3.
b)
Handwritten derivation of a 2x2 matrix eigenvalue problem: the matrix equation with entries -Ω, 2Ω/√3 is set equal to E times vector (A, B), giving two linear equations, a ratio A/B = 1/√3, and normalisation |A|²+|B|²=1 leading to |B|=√3/2, A=1/2.
last part of b) and all of c)
Handwritten working with an orange-red correction: the eigenvector (E-) = (1/2, sqrt(3)/2) in the |0>, |1> basis, and P(1) = (sqrt(3)/2)^2 with 25% struck out and 75% written in red.
I just don't understand the ratio method, it is a quicker method than mine or is it used more in more difficult matrices
  • Lecture slide, question 4: a qubit Hamiltonian matrix with entries 0, -Ω, -Ω, 2Ω/√3 in the {|0>, |1>} basis, with parts (a) eigenstates E+ and E-, (b) ground state eigenvector (A, B) with hint on the ratio A/B, and (c) measurement probability question.
  • Handwritten solution to a 2x2 eigenvalue problem: determinant of H minus E times identity equals zero, leading to E squared minus 2 root-3 E over root-3 minus Omega squared equals zero, giving E = root3 Omega or -Omega over root3.
  • Handwritten derivation of a 2x2 matrix eigenvalue problem: the matrix equation with entries -Ω, 2Ω/√3 is set equal to E times vector (A, B), giving two linear equations, a ratio A/B = 1/√3, and normalisation |A|²+|B|²=1 leading to |B|=√3/2, A=1/2.
  • Handwritten working with an orange-red correction: the eigenvector (E-) = (1/2, sqrt(3)/2) in the |0>, |1> basis, and P(1) = (sqrt(3)/2)^2 with 25% struck out and 75% written in red.
Check your work here. You cannot deduce that ##A=\sqrt 3## from equations [12] and [13]. These equations determine only the ratio of A to B.
It looks like you let ##A = 1## here; whereas, you claimed ##A = \sqrt 3##.
In the lecture's solution you find
Handwritten derivation of a 2x2 eigenvalue problem: a matrix equation with entries involving Omega and root 3, followed by two linear equations for A and B, a note marked consistent, and a blue arrow pointing to the ratio A/B = 1/root 3.
Check this. The last equation for ##\frac{A}{B}## does not look correct.
  • Handwritten derivation of a 2x2 eigenvalue problem: a matrix equation with entries involving Omega and root 3, followed by two linear equations for A and B, a note marked consistent, and a blue arrow pointing to the ratio A/B = 1/root 3.
Sorry, that was a typo. It is meant to be ##A=\sqrt 3 B## so then I through that as the simplest number for A would be 1 then B would be ##\sqrt 3## time that, so then I got the column vector: ##\begin{pmatrix}1\\ \sqrt{3}\end{pmatrix}##. Which the gave me ##E_{-} = |0> + \sqrt 3 | 1 >## and then I normalised
If you substitute ##A=1## in the relation ##A=\sqrt 3 B##, what do you get for ##B##?
Sorry, i will correct this and hopefully will have the correct ans this time. ##E_-=\begin{pmatrix}1\\ \frac{1}{\sqrt{3}}\end{pmatrix}## so then once I have normalized I get the following, ##|E_->=\frac{\sqrt{3}}{2}|0>+\frac{1}{2}|1>## So then my ans for c) would be ##25 ##%. Hopefully this is now correct?
Yes, that looks correct.
