Finding Electric Field due to hemispherical charge distribution
3 replies · 9K views
S[e^x]=f(u)^n
I need to find the electric field along the Z-axis for a hemispherical open shell of radius R (open face down). the shell is oriented so its symmetrical about the Z axis.
What I've done is set it up, taken the vector from the origin (at the center of what would be the full sphere), and subtracted the vector bound to the z axis, to get the vector from the differential surface of the shell to an arbitrary point on the z axis. I then integrate, using spherical coordinates the 1/r^2 expression...
I can't seem to get this to work, can someone guide me through the right steps?, I've been trying to do this for about 7hrs now, and feel really stupid since I'm a 3rd year uni student majoring in physics...
consider any thin circular strip on hemisphere at angle θ from vertical and subtending angle dθ on center.
find field due to this just like you do for ring on axis
then integrate it from θ = 0 to 90 degree
I've tried that, and i end up with E= [(surface charge density)*(R)^2]/[2*epsilon*(R-z)^2]
where R is the hemispheres radius, and z, is a point on the z axis...
i then integrate this to find the potential between R (along the z axis), and the origin, which ends up in a divide by 0 error... so i know the Electric field equation cannot be right although it seems to check out dimensionally...
is there an easier way to find the potential between the origin and R(on the z axis) that I'm missing? right now I'm just going after the electric field, which should then lead to a simple integration to get the potential difference between the two points. or have i forgotten something?
Perhaps you could show how you arrived at that? The well-known result for the on-axis field produced by a ring of charge Q of radius a and distance x is given by:
[tex]E_x = \frac{{kQx}}{{\left( {x^2 + a^2 } \right)^{{3 \mathord{\left/<br /> {\vphantom {3 2}} \right.<br /> \kern-\nulldelimiterspace} 2}} }}[/tex]
