Finding Equilibrium concentrations with added solutes?
  • Thread starter Thread starter Melvincalvin
    Equilibrium
The discussion revolves around determining equilibrium concentrations in a chemical equilibrium involving hydrofluoric acid (HF) and sodium fluoride (NaF). Participants are exploring how to incorporate the dissociation of NaF into their calculations, particularly in the context of an ICE table and the equilibrium constant (Kc).
  • Homework-related
  • One participant presents the equilibrium reaction for HF and asks how to factor in the concentration of NaF, which is not part of the equilibrium equation.
  • Another participant explains that NaF dissociates into its ions, contributing to the concentration of F- in the solution.
  • Some participants express confusion about how to correctly apply the initial concentration of F- from NaF in the ICE table and how it affects the equilibrium constant.
  • There is a suggestion to simplify calculations by making assumptions about the changes in concentration (1-x ≈ 1 and 0.5+x ≈ 0.5).
  • Participants discuss the importance of correctly setting up the ICE table and using the given equilibrium constant to find the equilibrium concentrations.
  • One participant questions whether to add the concentration of NaF directly to F- when calculating equilibrium concentrations.
  • Another participant reminds others to guide rather than provide direct answers, adhering to forum rules.
Participants generally agree on the need to use the ICE table and the dissociation of NaF, but there is uncertainty regarding the correct application of these concepts to find the equilibrium concentrations. The discussion remains unresolved regarding the specific integration of NaF into the calculations.
Some participants express difficulty in achieving the correct equilibrium constant, indicating potential misunderstandings or missing steps in their calculations. There is also a reliance on assumptions that may not hold in all cases.
Melvincalvin
HF(aq) ↔ H+ + F-
Determine equilibirum concentrations with Initital concentrations and Kc.
Kc = 7.2 x 10-4
[HF] = 1.00M
[NaF] = 0.50M
I understand how to do an ICE table and put together questions, but what do you do with [NaF] when it is not part of the chemical equation? How to I factor it into it? Thanks!
Chemistry news on Phys.org
What you have to remember is that ionic salts dissociate into their ions when in solution.
Consider the dissociation reaction of the NaF:
NaF → F- + Na+
Hopefully that should help you understand what to do.
NaF → F- + Na+
So the if it all dissociates then the initial concentration for F- should be 0.5M. I use that molarity but it still doesn't seem to work out. I can't seem to get anything to equal the equilibrium constant.
It is possible that I am misunderstanding. You were asked to find the equilibrium concentrations correct?
so you should have an ice table similar to this:
HF(aq) ↔ H+ + F-
i 1M 0M 0.5M
c -x +x +x
e 1-x x 0.5+x
from here you should be able to create your equilibrium expression of Kc = [products]e/[reactants]e
then if substitute in your expressions from ice table and the equilibrium constant you should be able to calculate x and then determine all of your equilibrium concentrations.
You should also note that it is probably acceptable to assume that 1-x ≈ 1 and that 0.5+x ≈ 0.5. this makes your calculations much simpler.
You were already given the equilibrium constant. you are solving for the equilibrium concentrations are you not?
I can setup my ice table like that fine, but where does [NaF] come into play, do I just add 0.50M to F- when I have equilibrium concentrations??
thank you for the help btw :) !
Have you checked the ICE table Ryan Schmidt gave you? 0.5 is already in the I (initial) line, taken care of.
@Ryan Schmidt - please don't go too far with help, by forum rules we guide people to the answer, not give it to them.
10K
9K
