Finding Fourier Transforms of Non-Rectangular Pulses
16 replies · 3K views · last reply
Electrical Engi321
Hi,
In class I have learned how to find the Fourier transform of rectangular pulses. However, how do I solve a problem when I should sketch the Fourier transform of a pulse that isn't exactly rectangular.
For instance "Sketch the Fourier transform of the following 2 pulses"
Thanks in advance, I would have known how to exactly solve the problem if it was rectangular :(
Hello EE, :welcome: !
You most likely have learned a few things more - they are required for this exercise:
  1. FT is linear: FT of a sum is sum of FT's and vice versa
  2. FT of a product is a convolution and vice versa
And the exercise consists of recognizing which is which.
Start with convolving two rectangles to see what you get ...
Oh, and this kind of exercise qualifies as homework in PF. For which we have
https://www.physicsforums.com/threads/homework-help-guidelines-for-students-and-helpers.686781/
so next time we'll need a genuine effort (attempt at solution) from you :wink:
  • Love
Do you mean that g1 is the convolution of a linear function overlapped with a rectangle pusle? On both the negative and positive axis?
Almost, but: it is not. Did you follow my simple advice ? What do you get when you convolve two rectangles ?
One way to do this could be to look at the derivative two times, and graph the dirac amplitudes, then you get dirac functions as amplitudes (for the second derivative) then you conduct the Fourier of a derivative twice (iw)^2 (on the left hand side) and on the right hand side then you get dirac functions which become e^... Then you divide both sides with (iw)^2 and get the X(w) = ... e^... divided by (iw)^2 which you can graph in your calculator and hence make a sketch.
However that is when you do a Fourier with the variable w right (omega) now we have the Fourier transform in f where f=2*pi*w
Do you understand my concern, or do the way I suggested also work to draw the Fourier (instead of thinking in convolutions)?
You probably mean that you get a triangle when you convoluted two rectangles? I still don't really understand how this would help me. Can I use the sum of a 1. Rectanle pulse Fourier transformed 2. Triangular pulse? So
F(Rectangle + Rectangle*Rectangle) sort of thing?
You're getting there ! Carry on ...
which of the 2 methods do you think is the best way to go forward? I made 2 posts in a row, you maybe missed the first.
I reponded to #6. Never saw #5 -- looks very convoluted (pardon the pun :wink: ).
Where the * representens convolution. So the left picture is the convolution of the 2 red graphs?
No, unfortunately not correct. If a plus sign explains g1, then this convolution certainly does not.
Counter-indication: the jump in g1
Work out the right-hand side using the definition of a convolution to prove it for yourself. Not all that complicated and very enlightening.
I am becoming a bit more lost now haha.
The problem I think that I have hard to understand is that we are suppose to find the Fourier transform in Frequency domain and not omega. I were to set up an easy equation using heaviside and dirac to express this graph and use wolfram to find the Fourier it wouldn't give me it in Frequency domain. This is what makes me stuck I reckon
You have seen that a convolution of two rectangles gives a triangle. Spend a few moment trying to understand why the convolution of a triangle and a rectangle should involve some ##t^2## -- so this does not appear in your exercise.
If that is asking too much, you can have it chewed out for you here (but I really think you should try it for yourself first
Not 'sort of', but spot on !
Bedtime for me so I'll leave you to do g2 on your own. Ask yourself: if I get a triangle from two identical squares, what has to change to get a flat ceiling ?
Oh, and Wolfram is a nice crutch, but you want to learn to walk and run without
I'm confused on what the issue here is, and really confounded on why this has gone into the issue of convolution.
Presuming that you know the general equation of transforming from spatial to frequency domain, what exactly is the problem here?
The functions you were given in the attachments are symmetric, so you only need to multiply the function that you made with a cos function and integrate from 0 to ∞.
And oh, you definitely should know that ω = 2πf.
Is the source of the problem here is that you are unable to come up with the appropriate function in the first place?
Zz.
Hello Zz,
I have the distinct impression that the purpose of this exercise is that the student should learn how to make good use of the linearity and the convolution theorem. True, I don't have the textbook and I can't read the writer's mind, but still:
Summary:: Finding Fourier transform of pulses that are not rectangular.
And of course the fact that the given shapes are so easily obtained from rectangular
The reactions of EE have not given me reason to change opinion. It is clear that he/she is still in an early stage of the curriculum for this most relevant topic.
The other way to do this intuitively is to use the fact that the square pulse is the derivative of the triangle pulse and proceed on that basis in frequency space. That is what I thought was the author's intent.
