Finding g from Atwood's Machine
  • Thread starter Thread starter jessicak
    Machine
The discussion revolves around calculating the acceleration due to gravity (g) using Atwood's machine with masses of 450g and 452g. The experimenter measured a distance of 0.472m in 5.8s, leading to an initial calculation of acceleration (a) as 0.0022g. However, using the formula a=2y/t² resulted in an incorrect value of g at 12.8 m/s². After further calculations, a more accurate value of g was suggested to be around 13 m/s², indicating potential experimental errors in the setup. The conversation emphasizes the importance of deriving equations rather than relying solely on memorization.
jessicak
1.Homework Statement
Two masses hang from a string running over a pulley. Such a device can be used to measure the acceleration of gravity; it is then called Atwood's machine. If the masses are nearly equal, then the a of the masses will be much smaller than g; than makes it convienient to measure a and then calculate g. Suppose than an experimenter using masses m1= 450g and m2=452g finds that the masses move a distance of 0.472m in 5.8s starting from rest. What value of g does this imply? Assume the pulley is massless.
I know that a=(m2-m1/(m2+m1))g
From the above equation, I know that a=0.0022g
When using a=2y/t2, though I get g=12.8m/s/s, which is wrong (online hw).
Can anyone point me in the right direction?
yes, but you should derive that equation instead of looking it up.
I get g=12.6, which probably in either case should be rounded to 2 significant figures, g=13m/s/s.. Looks like there was a lot of experimental error in that setup.
  • · Replies 97 ·
16K
  • · Replies 29 ·
10K
