Finding gauge pressure when the faucet is turned off
10 replies · 5K views · last reply
tyro008
The main water line enters a house on the first floor. The line has a gauge pressure of 1.70 X 10^5 Pa.
(a) A faucet on the second floor, 5.2 m above the first floor, is turned off. What is the gauge pressure at this faucet?
Pa
(b) How high above the water main could a faucet be before no water would flow from it, even if the faucet were open?
P(gauge)=[tex]\rho[/tex]gh
Pabs = Patm + Pgauge
Pabs = 1.01 X 10^5Pa + [tex]\rho[/tex]gh
density of water = 1000kg/m^3
i tried to use both of these equations but it didn't work. do i need to use 1.70 X 10^5Pa when solving the problem?
I tried the first equation and got 51012Pa (1000 X 9.81 X 5.2)
i tried using the second one and got the wrong answer too.
then i tried to find the density at the closed water fountain.. but i wasn't even
sure how to use that information.
which equation should i use to solve a?
i'm sure i can solve b after finding this.
How do you find the difference in pressure between two points in a fluid?
i'll just use "p" for rho..
i thought the difference might be pgh, and that pgh would be the gauge pressure.
so i just multiplied density of water by gravity by height.. but that didn't work.
i just don't know if there's supposed to be a different equation, since the faucet is
closed and thus a closed valve (i'm not even sure it's a closed valve..)
That's it.
Try it again. Note that ρgh is the change in pressure.
ok this time i tried the differences in gauge pressure,
so i subtracted pgh from 1.70 X 10^5Pa, and got 118988Pa..
would this be the right answer?
to find the height, would i use torricelli's theorum and then find V1 (velocity 1)?
No. To find the height needed for part (b) you'll do the same sort of thing you did for part (a). In part (a) you were given a height and you found the pressure difference; for part (b) you have the pressure difference (you can figure it out) and need to find the height.
What must the gauge pressure be for no water to flow? What's the pressure difference at that height compared to the pressure at the main level?
would the gauge pressure have to be zero for no water to flow?
and the pressure difference would be gauge pressure, what I calculated in (a), I think.
Right!
No. What you calculated in (a) was the pressure difference for a 5.2 m change in height.
For (b) the pressure difference is between the main line pressure (given) and a gauge pressure of zero.
