Finding IC Chip for 7-Segment Hex Decoder - SMD Package
  • Thread starter Thread starter Jiggy-Ninja
    Ic
The discussion revolves around the challenge of finding a suitable integrated circuit (IC) for a hexadecimal to 7-segment decoder in a small surface-mount device (SMD) package. Participants explore various alternatives, including using random logic, microcontrollers, and programmable devices, while addressing the difficulties in sourcing specific components and programming them.
  • One participant is designing a circuit board for a byte displayer using 7-segment displays and is struggling to find a binary to 7-segment hex decoder still in production.
  • Another suggests using random logic, but expresses concerns about the complexity and space requirements of the necessary gates.
  • Some participants mention the availability of BCD to 7-segment decoders but clarify that the original request is for a hexadecimal to 7-segment decoder.
  • A participant proposes using a binary ripple counter with a binary to BCD converter as a potential solution.
  • Concerns are raised about the limitations of BCD to 7-segment decoders, particularly their inability to display values above 9.
  • One participant suggests the DM9368 as a potential solution, although its availability and price are questioned.
  • Discussions include the high cost of programming adapters for SMD packages and alternatives for programming surface-mount PLDs.
Participants express a range of views on potential solutions, with no consensus on a specific IC or method to achieve the desired functionality. The discussion remains unresolved regarding the best approach to find or implement a hexadecimal to 7-segment decoder.
Participants note the difficulty in sourcing specific components, the high cost of programming adapters, and the limitations of existing BCD to 7-segment decoders for displaying hexadecimal values.
Jiggy-Ninja
I'm designing a simple little circuit board for prototyping purposes (a byte displayer using a pair of 7 segment displays).
Problem is, I can't find a binary->7-segment hex decoder still being made anywhere. I found a couple leads on Google, but Digikey and Mouser showed them as discontinued. I'd prefer a small SMD package (SOIC or TSSOP), since I''d like the board to be as small as possible.
If not, I'm willing to program an http://ca.mouser.com/ProductDetail/Atmel/ATF16LV8C-10XU/?qs=sGAEpiMZZMvwLjDpJZyitOLIDNjXIEtrQxy19NCE7eA%3d" to do the job. I have access to a programmer and WinCUPL software, but it only fits DIP packages. How do you program an SOIC or TSSOP without some expensive $85 adapter socket?
You could do it in random logic. It doesn't require that many gates.
You mean with 7400s, '04s, and whatever?
Unless I did my k-maps wrong or there's some technique I don't know, I'd need 7 OR gates with 3-4 inputs each, and 20 at least 20 AND games with 3-4 inputs each. with the smallest chip size possible, that's a lot of board space with a lot of traces running around. And it's be hell to solder.
And that's just with DCBA inputs; I'm not counting RBI, LT, or CE because I don't really care about those for this application.
Why the hell are the programmers so expensive? I can hardly find any for <$100.
A Parallel in/out EEPROM would work, as log as it wasn't much bigger than necessary (16x8 is all that's needed), cheap enough, easy to program without fancy parts.
small microcontroller?
@ Digikey:
296-2079-5-ND
296-3528-1-ND
568-3125-5-ND
All of these are under a dollar, in stock, and have a minimum quantity of 1. Digikey has tons of them - try a search for "BCD-7".
Or try this:
http://cgi.ebay.com/1-pc-74LS47-BCD-7-Segment-Decoder-DIP-16-pin-IC-/170467158261
KingNothing said:
@ Digikey:
296-2079-5-ND
296-3528-1-ND
568-3125-5-ND
carlgrace said:
Or try this:
I already found (and bookmarked) several BCD->7-segment decoders. I've had no trouble finding several different kinds of those. I'm looking for a Hexadecimal->7 segment decoder. I can't find that anywhere.
Oh, OK. Binary to BCD is trivial (and doesn't use many chips).
http://www.electro-tech-online.com/...208347753-binary-bcd-converter-binary-bcd.gif
Then put the output into one of the bcd-to-7-segment display chips KingNothing found.
Jiggy-Ninja said:
I'm trying to get the haxadecimal to display on one 7-segment, not two. That solution doesn't help.
I think you're misunderstanding me. The circuit in that .gif converts a nybble to BCD. Use two of them to convert your byte. Then concatenate the outputs and send to the BCD-to-7-segment display driver.
At the moment, I'm not looking to convert binary to BCD, thought that's a good backup plan if I can't do what I'm trying to do.
I'm trying to get a display like this:
And can't find a chip anywhere to do it.
...and the simplest way to do that is a binary ripple counter driving a binary to BCD converter...
I don't get it. Most of the BCD->7-segment decoders I've found show either gibberish or blanks for anything above 9. How does your scheme let me display A-F?
You may be right. I have only used one 7-segment display and we designed our own decoder (for a lab class) that accepted A-F.
You want the DM9368. It will do the job. There is one here:
http://cgi.ebay.com/DM9368N-Integrated-Circuit-x-1-pieces-DM9368-/150583168277
But you may be able to find it elsewhere, cheaper, if you do some digging.
Good luck.
I believe that's one of the chips I came across that's discontinued. $30 is a ridiculous price for a chip as simple as this, and I don't really know where else to look.
For programming a surface-mount PLD, would getting a board like http://www.epboard.com/eproducts/protoadapter.htm" and just pressing the IC onto it while it's in the programmer work in a pinch?
I agree, $30 is ridiculous. There are FPGAs that cost around $7 and microcontrollers less than $2. Good luck, sorry I could not be of more help.
