- #1
Crusaderking1
- 159
- 0
A juggler throws a ball just so it reaches the ceiling at 3.0 meters. (3m above hand)
How do I solve for initial velocity?
Crusaderking1 said:Homework Statement
Initial velocity in free fall is the velocity of an object at the beginning of its free fall motion. It is the speed and direction at which the object starts falling.
Initial velocity in free fall can be calculated using the formula v = √(2gh), where v is the initial velocity, g is the acceleration due to gravity (9.8 m/s²), and h is the height from which the object is falling.
Yes, initial velocity in free fall can be negative if the object is thrown downward or if it starts from a higher point and falls downward. A negative initial velocity indicates that the object is moving downward with a certain speed.
The units of initial velocity in free fall are meters per second (m/s) or feet per second (ft/s), depending on the unit system used. It represents the rate of change of displacement with respect to time.
Air resistance, also known as drag, can have a significant impact on the initial velocity of an object in free fall. It can cause the object to decelerate and reach a lower terminal velocity, which is the maximum velocity an object can reach in free fall due to air resistance. This can result in a lower initial velocity compared to an object falling in a vacuum.
