Finding initial velocity of a cat jumping through a hoop
To find the initial velocity of Kit the cat jumping through a hoop, the problem involves calculating vertical and horizontal components of motion. The cat starts at a height of 1.745 m and reaches a peak height of 3.115 m, with the hoop located 1.567 m horizontally away. The vertical motion can be analyzed using kinematic equations, particularly Vf² = Vi² + 2a(y2 - y1), to determine the initial vertical velocity. Time can be calculated using the equation y(t) = y_o + v_o t + 1/2 at², which should include the initial height. The correct time value is approximately 0.529 seconds, which can then be used to find the initial horizontal velocity.
Brianna I
Kit the cat is going to jump through a hoop. He begins on a wicker cabinet at a height of 1.745 m above the floor and jumps through the center of a vertical hoop, reaching a peak height 3.115 m above the floor.
With what initial velocity did Kit leave the cabinet if the hoop is at a horizontal distance of 1.567 m from the cabinet? (Express your answer in vector form)
X (or Y) = vit + 1/2at2
Vf2 = Vi2 + 2a(x2-x1)
And possibly quadratic equation.
I was able to calculate the initial velocity of the y direction using Vf2 = Vi2 + 2a(x2-x1) (I know because the cat reaches peak height at 0, the vertical velocity at that time was 0).From there, I tried to solve for t. I know once I get t, I can find the initial velocity of x, but I came to an error in what I believe is my t. I tried plugging into Y = vit + 1/2at2 and made it into the quadratic formula, but got two positive answers 0.54739930925614 s and 0.51076395604999 s. Then I tried the Vf = Vi + at and got .529 s.
What can I do to find time, correctly?
Your final method works fine. t = 0.529 s looks good.
Your other method would have worked, too if you had included the initial height. That is, the more complete version of the kinematic equation you used is:
##y(t) = y_o + v_o t + \frac{1}{2} a t^2##
Note the ##y_o## term representing the initial offset ("launch height" in this case).
10K
