Finding initial velocity of a free-falling object that launched off a cliff
The problem involves a radio-controlled model car that falls off a dock, with participants discussing how to determine the car's initial speed based on its displacement after a certain time. The context includes concepts from kinematics and projectile motion.
  • Mixed
  • Participants explore various kinematic equations to relate displacement, initial velocity, and acceleration. Some express confusion about the distinction between displacement and velocity, while others question how to separate horizontal and vertical components of motion without an angle.
There are multiple interpretations of the problem, with some participants suggesting the use of diagrams and others proposing different assumptions about the direction of displacement. Guidance has been offered regarding the need to apply kinematic equations for projectile motion, though no consensus has been reached on the correct approach.
Participants note the lack of specified direction for the displacement and the challenge of mixing horizontal and vertical components in their calculations. Some express uncertainty about the sufficiency of the given information to solve the problem effectively.
kmb11132
A child operating a radio-controlled model car on a dock accidentally steers it off the edge. The car's displacement 0.77 s after leaving the dock has a magnitude of 7.4 m. What is the car's speed at the instant it drives off the edge of the dock?
@t = .77s displacement is 7.4m
a = -9.8m/s^2
1. v_f^2 = v_i^2 + 2ad
or
2. d = v_i * t + (a * t^2)/2
v_f = 7.4/.77 = 9.61m/s
1. 9.61^2 = v_i^2 + 2 * -9.8 * 7.4
... v_i = 13.38m/s, incorrect (aware of incorrectly mixing x and y components)
2. 7.4 = v_i * .77 - (9.8 * .77^2)/2
3. Making a right triangle by finding v_f of an initially stationary object falling for .77s:
at + v_i = v_f
-9.8 * .77 = v_f
v_f = -7.55m/s
9.61^2 = 7.55^2 + b^2
b = 5.95
so v_i = 5.95m/s, incorrect
a = -9.8m/s^2
or
Umm, I think this might be where you got off a little. Displacement is not the same as velocity. Displacement is a distance.
Try using another of the equations for uniformly accelerated motion to work on this one.
So what I found would be v_av not v_f correct? I'm kind of stuck right now because I don't think I can use equations that incorporate v_f, and those that incorporate v_i, a, d, and t all produce 13.38 as the initial velocity. I don't think I can separate this problem into vertical and horizontal components because I don't have any sort of triangle, but I get the impression that this is somehow what must be done. This is because the acceleration in directly downward, and v_i I'm looking for is directly eastward, and the distance I'm given falls in between these two. Any further hints would be greatly appreciated.
A diagram might help!
Since you didn't specify the direction of displacement (7.4 m horizontally, vertically, or diagonally from the dock), I would assume diagonal displacement.
Assuming the car fell at a 45 degree angle the magnitude of its x displacement would be 5.23 meters in .77 seconds. Without an x acceleration/assuming constant speed this would work out to a v_ix of 6.79m/s. This is also incorrect. There is still some key to solving this problem that's missing here and I'm seriously at a loss for what it is. That's a really nice diagram, by the way, gneill.
The car won't fall at a 45° angle, it will follow the parabolic path of a projectile. The horizontal velocity will be constant, but the vertical velocity accelerates downwards due to gravity. You need to use the kinematic equations for projectile motion.
That's what I thought, but I figured in the absence of all other ideas I'd give a 45-45-90 triangle a shot. I tried all of the kinematic equations for projectile motion in every way that I thought made sense and they all incorrectly lead me to a v_ix of 13.38m/s. I know that I'm using the equations incorrectly because I'm mixing vertical and horizontal components. The problem is without an angle I can't figure out how to split the given information into vertical and horizontal components.
Given some (as yet unknown) initial horizontal velocity Vo, write the expressions for the X and Y positions of the car with respect to time. For simplicity, take the downward direction to be positive, then the acceleration will be positive, too.
Thank you so much! I didn't think there was enough information to do that but, well, there definitely was.
For the sake of future Googlers coming to this page what I did was...
Take this equation: d = v_i*t + .5*a*t^2
and solved for the y displacement:
d_y = 0 * .77 + .5 * -9.8 * .77^2
d_y = -2.9m
This gives me a displacement right triangle. Using the Pythagorean theorem I determined that:
d_x = 6.8m
Knowing that this distance was traveled over .77s, and that horizontal velocity is equal throughout free-fall:
v_i = (6.8m / .77s) = 8.83m/s
