Car accelerating from 234 km/h at 9 m/s² for 20 seconds
5 replies · 2K views
-Physician
The car goes with a initial velocity of 234km/h, and accelerates 9m/s2 for time of 20s. Find the displacement of the car in accelerating uniformly motion and the final velocity. Also the find the change in velocity !##Δv##
##v_i=234\frac{km}{h}=234\frac{1m}{3.6s}##
##a=9\frac{m}{s^2}##
##t=20s##
##d=v_0t+\frac{1}{2}at^2##(Find)
##v_f=v_0+at##(Find)
##Δv=v_f-v_i## (Find)
Just waiting an answer :) thanks! (i know you may not answer because you don't do our homework but you help us, but i really need help for this)
You have the equations to use. The speed is given in km/hr but the acceleration rate is in m/sec^2. You must convert to like units before adding the terms in the displacement equation.
I see, but
, what does that mean, does anything change?
It should be stated "accelerating uniform motion". Motion is a noun so it needs an adjective not an adverb as a modifier.
That said, the term means that the acceleration is constant. The equation is not valid unless the acceleration is constant over the specified time, t.
Oh thanks so:
##v=234 \frac{km}{h}=234 \frac{1m}{3.6s}=65 \frac{m}{s}##
##v_f=v_i+at=65 \frac{m}{s} + (9 \frac{m}{s^2})(20s)=65 \frac{m}{s} + 180 \frac{m}{s}=245 \frac{m}{s}##
##d=v_0 t + \frac{1}{2} at^2=(65 \frac{m}{s})(20s)+ \frac{1}{2}(9 \frac{m}{s^2})(20s)^2=1300m+1800m=3100m=3.1km##
Is that correct?
Yes, it is correct.
