Limit of (x^3-2x^2-9)/(x^2-2x-3) as x->3 | Homework Help
  • Thread starter Thread starter asd1249jf
    Limit
To find the limit of (x^3-2x^2-9)/(x^2-2x-3) as x approaches 3, it is essential to factor both the numerator and the denominator. The denominator factors to (x-3)(x+1), indicating that x=3 is a root of the denominator. The numerator also has x-3 as a factor, which can be confirmed through polynomial division or factoring by grouping. After factoring, the limit can be evaluated by canceling the common factors. This process leads to a simplified expression that allows for direct substitution to find the limit as x approaches 3.
asd1249jf
Find the limit of
\frac{x^3-2x^2-9}{x^2-2x-3}
as x->3
You factor the bottom portion and top portion, then it looks something like this
\frac{x(x^2-2x)-9}{(x-3)(x+1)}
I feel like I can go further about eliminating the demonimator but I don't know what
Is 3 a root of the polynomial x^3- 2x^2 - 9 ? If so, what is then factoring of this polynomial ?
(x - 3) is a factor of the numerator. You can use either synthetic division or plain old polynomial division to find the other factor.
... or notice that
x^3-2x^2-9 = x^3-3x^2+x^2-9
and factor by grouping.
l46kok said:
Find the limit of
as x->3
No, you did NOT factor the numerator. That is not what "factor" means.
I assume you tried first just putting x= 3 into the fraction and found that both numerator and denominator were 0 when x= 3. The fact that the numerator was 0 tells you that it has a factor of x- 3. x^3- 2x^2- 9= (x- 3)(ax^2+ bx+ c)
It shouldn't be hard to see what a, b, and c must be.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 105 ·
