How Do You Calculate the Rotational Inertia of a Hollow Cylinder?
To calculate the rotational inertia of a hollow aluminum cylinder, the mass of both the outer and inner cylinders must be determined using the density formula. The outer cylinder's mass is calculated as 2100.89 g, while the inner cylinder's mass is 525.22 g. The moment of inertia is then found by subtracting the inner cylinder's inertia from the outer cylinder's inertia using the formula I = mr^2. The final result for the rotational inertia is 0.001134 kg*m^2. The discussion also highlights the correct moment of inertia formula for a solid cylinder, which is I = 1/2 MR^2.
Oomair
A pipe made of aluminum with a density of 2.7 g/cm3 is a right cylinder 43 cm long whose outer diameter is 4.8 cm and whose inner diameter is 2.4 cm. What is the rotational inertia about the central axis of the pipe? Note that the rotational inertia of the thick cylinder can be expressed as the rotational inertia for a solid cylinder of radius R2 minus the rotational inertia of the solid cylinder of radius R1.
D= m/v I= mr^2 for a solid cylinder volume of a cylinder = piR^2H
what i basically did is find the mass of the two cylinders
D=m/v outer cylinder = 2.7g/cm^2 = m/v and inner cylinder = 2.7g/cm^2 = m/v
mass of the outer cylinder comes out to be 2100.89g and inner cylinder comes out to be 525.22g
then i put them into the moment of inertia equation I= mr^2
((2100.89g)(2.4cm)^2) - ((525.2g)(1.2cm)^2) = 11344.81 g*cm^2, then i convert it into kg*m^2 and i get .001134 kg*m^2, anything wrong I am doing here?
Hi Oomair,
The moment of inertia of a solid cylinder about its central axis is:
<br /> I=\frac{1}{2}MR^2<br />
  • · Replies 40 ·
