Finding pin reactions on a triangular plate loaded at one point
  • Thread starter Thread starter jwtp45
    Forces Moments
2 replies · 3K views
jwtp45
A triangular plate is attached to a wall by two pins A and B. It is loaded at point C by A force F
Sum of Moments = 0
Sum of Forces = 0
Moments act around bottom of plate
F*L1=L2*Fa+L3*Fb
Vertical Forces
F=Fa+Fb
Fb=F-Fa
Horizontal Forces
F=0
So vertical forces into moments
F*L1=L2*Fa+L3*(F-Fa)
Fa= F (L1-L3)
L2 - L3
It doesn't feel right can someone tell me if I've done it right cheers
Sum of Moments = 0
Sum of Forces = 0
Moments act about any point you choose, not just the bottom of the plate. For objects in equilibrium, the sum of moments about any point is zero.
F*L1=L2*Fa+L3*Fb
This moment equation about the bottom of the plate is not correct. You first need to use F_ax and F_bx, not Fa and Fb, And your moment arm from F_ax to the bottom of the plate is wrong. It is easier to sum moments about B to solve for F_ax.
Vertical Forces
F=Fa+Fb
Fb=F-Fa
Again, here it should be F_by = F - F_ay, and you can assume that F_ay and F_by are equal.
Horizontal Forces
F=0
You mean F_netx = 0?
what do you mean by this?
Fa= F (L1-L3)
L2 - L3
Try again summing moments about B. What is the problem asking?
