How can I calculate projectile distance with limited information?
  • Thread starter Thread starter lukus09
    Projectile
To calculate projectile distance with limited information, start by determining the vertical and horizontal components of the initial velocity using trigonometry. The vertical component allows you to find the time of flight by setting the final vertical velocity to zero at the peak height and applying the equation v = u + at. Once the time of flight is established, double it to account for the total time until the object hits the ground. For horizontal distance, use the initial horizontal velocity and the total time in the air to calculate distance with the formula distance = speed × time. Additionally, the range equation R = [v^2sin(2θ)]/g can be used for a quick calculation if the initial velocity and angle are known.
lukus09
i am looking to find the projectile distance if an object (any object) was launched at 50 degrees considering the only information i know is u and v and theta (50)
can someone help me out on the formula i need in order to calculate the range?
as this is a projectile you also know the accelration in the vertical direction to be gravity. 9.81 m/s^2.
what you want to do is separate this question into vertical and horizontal. so if you konw the inital velocity, u, at an angle of 50 then you can work out the vertical intial velocity using basic trigonometry.
vertical: you now have vertical inital velocity,u, and you know that when it reaches its heighest point its final velocity, v, will be 0. now you have u, v, a and so you can find the time in the air using v = u + at. once you have found t, double it so you have the total time in the air until it hits the floor and you can use this time for you horizontal calculations.
horizontal: you now have time, t, and you can find the inital velocity again using tigonometry and now just you the equation speed = distance/time to find your projectile distance.
sorry its a bit of a long explanation. i hope it helps
i also think there's a range equation that looks a lil somehting like this
R = [v^2sin2(theta)]/g
but I am not 100% sure about that
26K
  • · Replies 53 ·
  • · Replies 35 ·
