Finding Remainders for Large Numbers Modulo 5
12 replies · 3K views
cheiney
(a) Find the remainder when 1^99 + 2^99 + 3^99 + 4^99 + 5^99 is divided by 5.
(b) Generalize this result
Congruence Modulo
a[itex]\equiv[/itex]b mod n
also
a=n*q+b where q is some integer.
The remainder for 1^99 would be 1.
The remainder for 5^99 would be 0.
I'm having difficulty finding the remainder for 2,3,4.
I'm assuming I have to use modular arithmetic to find the remainder for these, but I'm not sure where to start. Anyone care to point me in the right direction?
jbunill has offered you an idea, which is a good one. However if you are still not sure how to proceed, try this: compute each of ##2^n## mod 5 where n = 0,1,2, .. 7. Observe what happens. From that point you should be able to compute ##2^{99}## mod 5.
Thanks everyone for your posts. I figured out the answer to both parts.
Part a) , the remainder is 0.
Part b) , If you sum n integers, where n is prime, and divide the sum by n, you will always get a remainder of 0.
P.S. Phinds and Mark44, I wrote it incorrectly. The remainder should be 1, not 5.
I especially appreciate brmath's post as this one made the most sense to me.
This is way too general... according to this claim, if I take 4 and 5, which is two integers, and I sum them, then divide by 2 I get a remainder of zero.
Ah, I didn't think of that. What if I specify n consecutive integers starting from 1?
Part (a) is not an example of that though... if it was
"Find 1+2+3+4+5 mod 5" then it would be, but as written it's not a sum of n consecutive integers.
Okay I understand what you are saying. What if I said:
If you sum 1^a+2^a+3^a+...+n^a (where n is a prime number) and divide this sum by n, you end up with a remainder of 0?
You can write 4 as -1 mod 5 and 3 as -2 mod 5.
( 1 mod5)^99 = (1 mod5)^98 *(1 mod5)
( -1 mod5)^99 = (-1 mod5)^98 *(-1 mod5),
the same with 2 mod5 and -2 mod5.
How are (k mod5)^98 and (-k mod5)^98 related?
ehild
Is it true if a even? For example, 12+22+32 divided by 3?
ehild
cheiney What is the connection between amod5 + bmod5 and (a+b)mod5? Figure that out by taking some examples.
Then figure out ##2^{99}, 3^{99}, 4^{99}## by the method I suggested earlier and use what you just learned about sums and mods.
It's best not to reach for general answers until you have worked out a number of specific cases.
