Finding Solutions to a Quartic Equation
  • Thread starter Thread starter Refraction
    Cubic
10 replies · 2K views
Refraction
I've been given the following quartic equation in a question:
[tex]x = (1 + 2a + a^2)x - (2a + 3a^2 + a^3)x^2 + (2a^2 + 2a^3)x^3 - a^3x^4[/tex]
and need to show that two of the solutions (that aren't 0 and 1) can be given by:
[tex]x= \frac{(2+a) \pm \sqrt{a^2 - 4}}{2a}[/tex]
2. The attempt at a solution
I think I have to start by dividing it all by x - when I put this new equation into wolfram alpha it gives the right answer, I just have no idea how to get there (or where to start), since I haven't done a whole lot with cubics or quartics before.
Hurkyl said:
Can you say why you think so?
Sorry, I left out a part of the equation above. It was actually x = [what I already gave], I've edited that in now. It just seems like that way it would be easier to rearrange into the form needed, I'm not 100% sure about that though.
what did you mean by putting the expression given as x into the equation? Putting it into the second one there/the other way around?
Sorry if my English failed.
Substitute value of x given in the second equation for all occurrences of x in the first equation. That will yield equation in "a" - and if second equation really gives solution, equation in "a" should be just an identity.
Would there be a reasonably simple way to get to the two results given without substituting them into the first equation? I have a feeling that I'm supposed to do it that way, and not just by replacing x with the answers given.
It seems like I could get to that form with some rearranging and factorising but I'm not sure where to begin with that, or if there's any specific techniques that might help.
Go back to your original equation and rewrite in the form f(x) = 0. Observe that you can factor out ax, so your equation looks like axg(x) = 0. Now g(x) is a cubic polynomial and you know that 1 is a root. Use long division to compute g(x)/(x-1). The result is a polynomial of degree 2. Now use the quadratic formula to find its roots. You end up with the result in your first post.
Thanks, that worked perfectly!
