What is the speed of the objects in a pulley system?
  • Thread starter Thread starter physics10189
    Pulley Speed
In a pulley system with a 5.9 kg object released from a height of 4.53 m, the speed of the objects can be determined using the principle of conservation of energy. The potential energy (PE) at the initial height converts to kinetic energy (KE) just before the object hits the floor. The equation used is PE(initial) = KE(final), leading to the formula v = sqrt(2gh), where g is the acceleration due to gravity (9.8 m/s²) and h is the height (4.53 m). The discussion highlights the importance of ensuring all variables are correctly accounted for, including the height and mass of the other object in the system. Ultimately, the final potential energy is considered zero at the moment before impact.
physics10189
Finding speed with a pulley?
Two objects are connected by a light string
passing over a light frictionless pulley as
shown in the figure. The 5.9 kg object is
released from rest at a point 4.53 m above the
floor.
The acceleration of gravity is 9.8 m/s2 .
What is the speed of the each object at
the instant before the 5.9 kg hits the floor?
Answer in units of m/s.
I use the energy equation where
PE(initial)=KE(final)
and solve for v but it does not seem to work
decrease in PE = increase in KE
Welcome to PF!
Hi physics10189! Welcome to PF! :wink:
Show us your full calculations, and then we can see what went wrong, and we'll know how to help! :smile:
well here is what i did
mgh=.5mv^2
h=Lcos(theta)
mass cancel out
so this is what i came up with
v=2gLcos(theta)
where L=10m of the string's length
whoops wrong problem
scrath the last reply
ok its the same way kinda
so here is what i did
mgh=.5mv^2
masses cancel out
h=4.53m
there for
v=sqrt(2gh)
Is the "final" PE of the system zero?
See my earlier post.
yes because just before the blocks hit the ground can we assume that the height is zero therefore the PE final is zero?
What answer are you getting?
A figure, or description, showing what is theta, the mass of the other object, etc., sure would help.
  • · Replies 33 ·
