Finding Tension is three cables attached to a particular mass?
5 replies · 8K views
savva
An object of mass m is suspended from a cable tied to two other cables, each fastened to a supporting beam, as shown below. The tensions in the three supporting cables are T1, T2, and T3. The diagram of the system is available via the link below:
http://i40.tinypic.com/15goxg3.jpg
The tension T1 = 1800 N.
I worked out the first three parts, but could not work out parts d) and e)
(a) Determine the horizontal component of T1.
(b) Determine the horizontal component of T2.
(c) Determine the tension T2.
(d) Determine the tension T3.
(e) Determine the mass of the suspended object.
Th = 1800cos(60) = 900N
Th = 1800cos(60) = 900N (The same component for T2) - The only thing is I do not understand why this is the same - I only knew to calculate it the same because I have the answers given.
T2 = 900/cos(40) = 1175N
Any help would be appreciated greatly
T1/sin40=T2/sin60=T3/sin 80
you can work out the T3 tension from this equality.and it is easily seen from figure mass m equals T3.
Try applying Newton's 1st Law in the horizontal direction to solve for the horizontal component of T2
using that method, I can't seem to get the correct answer:
1800/sin40 = 1175/sin60 = T3/sin80
((1800/sin40) - (1175/sin60)) x sin80 = 1421.6N
The answer for part d) T3 = 2313N
What method do I apply to get this if it is not the one I currently used?
Try applying Newton's 1st Law in the horizontal direction to solve for the horizontal component of T2. Then apply his 1st law in the vertical direction to solve for T3.
Newton's 1st Law:
[itex]\Sigma F_x = 0[/itex]
[itex]\Sigma F_y = 0[/itex][/color]
Ok, I've got it now, thanks for your help:
Information given as well as calculations done previously can help to solve part d and subsequently e.
Part d)
T3 = Tv1 + Tv2
Tv1 = 1800sin(60) = 1560N
Tv2 = 900tan(40) = 755N
Therefore, T3 = 1560 + 755 = 2315N
for part e)
m = T3/g = 2315/9.8 = 236kg
