Finding the acceleration of 2 blocks
The problem involves two blocks connected by a massless string over a pulley, with one block on a wedge-shaped ramp. The masses, angles, and coefficients of friction are specified, and the goal is to determine the acceleration of the blocks. Participants express confusion about the forces acting on the blocks, particularly regarding the use of sine and cosine components in the equations for tension and friction.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants discuss the force vectors acting on the blocks, questioning the roles of sine and cosine in the equations. There are attempts to visualize the forces and clarify the relationship between normal force and friction. Some participants express uncertainty about the correct application of these components in the context of the problem.
The discussion is ongoing, with several participants exploring different interpretations of the forces involved. Some guidance has been offered regarding the relationship between normal force and friction, but no consensus has been reached on the correct approach to the problem.
Participants are grappling with the implications of the acceleration of the system and how it affects the forces acting on the blocks. There is a focus on understanding the balance of forces in both static and dynamic scenarios, with specific attention to the components of tension and weight in relation to the normal force.
engphys204
A block of mass m1 = 2 kg and a block of mass m2 = 6 kg are connected by a massless string over a pulley in the shape of a solid disk having radius R = 0.250 m and mass M = 10 kg. The fixed, wedge-shaped ramp makes an angle of 30 degrees and the coefficient of kinetic friction is 0.360 for both blocks. Determine the acceleration of the two blocks. The only part of this problem that i don't understand is how to get the forces acting on the object:
T1 = μm1g+m1a
T2 = m2gsinθ−μm2gcosθ−m2a
I know you have to divide it into the sin and cos components but I don't understand why the cosine was used when it is sliding down the ramp. I thought only the sine should be used and that the cos would cancel out with the normal (N). Thanks in advance for any clarification!
Try to visualize it. Think about all the force vectors that are acting on either mass that run parallel to the surface their respective mass is on (I hope that's clear enough). I count 3. It should be easy from there.
I don't understand the term: μm2gcosθ.
I believe that is the frictional force acting on m2. Looks right to me.
Seems to me that it should be u (M2 g - T2 sin theta) cos theta.
I still don't understand why the cosine is used because when I draw out all the force vectors the mgcostheta cancels out with the normal force. :/ Unless I am drawing my force diagrams wrong.
Please explain your reasoning.
Yes, the normal force is equal and opposite to the component of gravity normal to the plane, i.e. mg cos(θ). Why is that a problem? How do you obtain the kinetic friction force from that?
This is the answer for the tension from my solution manual: T2 = m2gsinθ−μm2gcosθ−m2a
So if the cosine cancels out, my question is why does it still appear in the equation?
It only cancels out in the sense that there is no net force normal to the plane. But the friction is not related to the net force. It depends on the normal force, which is not zero.
The normal force is the resultant vector of T1 and the weight of M2.
T2 (I think you mean) is parallel to the plane. It has no component normal to the plane.
Yes, I meant T2.
Try putting the forces T2 and W2 on a force table.
What vector in the direction of N is required to balance the those 2 vectors?
T2 is perpendicular to N, but it is not perpendicular to the weight W2.
You can't use u W2 cos theta as the frictional force because T2 has a component
that lies along the vector W2 and that component is T2 sin theta.
I don't see any way around that.
(I didn't see your previous post where you mentioned that N is the resultant of W2 and T2)
W2cos(θ).
J Hann said:
T2 has a component. that lies along the vector W2 and that component is T2 sin theta
you can get yourself confused analysing things that way, but if you insist:
The system is accelerating, but to make the discussion simpler here suppose it is static. I'll drop the 2 suffix.
T has a vertical component Tsin(θ) (opposing) W. T=Wsin(θ), so that component is Wsin2(θ). Take that from W leaves Wcos2(θ). Likewise, N has a vertical component Ncos(θ) opposing W. Conclusion, N=Wcos(θ).
Since there is acceleration, it is much easier to analyse in the directions parallel and normal to the plane.
haruspex said:
W2cos(θ).
haruspex said:
W2cos(θ).
Well, I disagree with the statement T = Wsin(θ) and retract my statement that (M2 g - T2 sin theta) cos theta.
T = Wsin(θ) is true for the direction along the plane, but then you use Ncos(θ) which has no component along the plane.
If I were to balance forces in the vertical direction I would get N cos theta + T sin theta = W.
Which is entirely consistent with T=Wsin(θ) and N=Wcos(θ).
Well, my statement is OK for static forces only, but as you pointed out earlier there is an acceleration component in the
vertical direction, so that acceleration would need to be included in any dynamic solution.
However, there is no component of acceleration in the N direction, but both T and W have components
in the N direction so the Normal force must include both of these vectors when calculating the frictional force
and that seems to involve considerable "arithmetic" in solving the problem.
T has no component in the N direction.
I agree (finally) with that and that the value of N (the normal force) has to be N = M2 g cos theta.
