Finding the apparent acceleration due to gravity versus latitude
8 replies · 2K views
pandafish
A mass at rest on the surface of the earth at latitude λ , experiences a reaction from the earth that consists of a normal component S per unit mass and a tangential frictional component F per unit mass, directed towards a point vertically above the north pole. The earth is assumed to be a uniform sphere of radius R and mass M rotating with an angular velocity ω about its axis. How is the magnitude and direction of the apparent ’acceleration due to gravity’ g , acting on the mass at latitude , related to these forces?
Show that:
$$g^2 = [\frac{GM}{R^2}-R\omega^2cos^2\lambda]^2 + [\frac{1}{2}\omega^2Rsin2\lambda]^2$$
$$g=-\frac{GMm}{R^2}$$
I began by drawing a diagram and resolving the forces. Since the question asked for 'apparent gravity' I tried to find the normal force.
I started with the equations:
$$\\(\frac{GM}{R^2}-N)sin\lambda-Fsin\lambda=m\omega^2Rcos\lambda$$
$$\\(\frac{GM}{R^2}-N)sin\lambda-Fcos\lambda=0$$
Solving simultaneously, I ended up with:
$$\\N=\frac{GM}{R^2}-R\omega^2cos^2\lambda$$
The terms on the left cannot both be sine. F is tangential while the other force sum is radial. I don’t think having trig terms both sides is right either.
Which direction do you intend this force balance to be in?
My bad, its suppose to be:
$$\\(\frac{GM}{R^2}-N)cos\lambda+Fsin\lambda=m\omega^2Rcos\lambda$$
This force balance is suppose to be perpendicular to the axis of Earth's rotation.
Then why the cos on the right?
The right side is the centripetal acceleration,
$$a = \frac{v^2}{r} = \omega^2r$$
I believe r is distance from the mass to the earth's axis of rotation, so
$$a = \omega^2(Rcos\lambda)$$
I made a mistake by including mass on the right.
Sorry, I read R as though it was r.
You need an expression for g. Note how the problem statement defines g. It is not as used in your "relevant equation".
I see what you mean. Working backwards from the solution, I realised that the 'apparent gravitational acceleration' was made up from the normal force , and the component of the centrifugal force tangential to Earth's surface. However, I'm don't quite understand why this is the case.
Consider a mass placed on the surface. Apparent gravity is the net force per unit mass. This corresponds to the weight that would be recorded by a conventional weighing machine.
Thank you, that explanation makes it a lot clearer what the apparent force is.
