Finding the area beneath a curve help
  • Thread starter Thread starter dc2209
    Area Curve
To calculate the area beneath the curve y = 2x^2 + 7x + 24 from x = 2 to x = 5, the integral is set up as A = ∫(2x^2 + 7x + 24)dx. The correct indefinite integral is found to be (2x^3/3 + 7x^2/2 + 24x). Evaluating this from 2 to 5 and performing the arithmetic correctly yields an area of 223.499 units. The discussion emphasizes the importance of careful arithmetic in calculus, particularly when substituting limits.
dc2209
1. Hi, I have been asked to calculate the area beneath a curve. The curve is
y = 2x^2 + 7x + 24 and the values of x to find the area within are 5 and 2.
3. My attempt stands as follows: A = 5,2∫ (2x^2+7x+24)dx
[ 2x^3/2 + 7x^2/2 + 24x ]
From there I am unsure on what to do as i am unsure on calculus as a whole.
Thanks
Thanks
I presume that the "5,2" in front of the integral indicates that you are integrating "from x= 2 to x= 5". Do you know what that means? Yes, 2x^3/3+ 7x^2/2+ 24x+ C (C can be any constant) is the general anti-derivative. Now, evaluate that between x= 2 and x= 5. That is find the value of 2x^3/3+ 7x^2/2+ 24x+ C at x= 5, at x= 2 and subtract the first from the second.
If F'(x)= f then \int f(x)dx= F(x)+ C and \int_a^b f(x)dx= F(b)- F(a)
Look at the way you calculated the integral.
Also when calculating a definite integral what makes it different than an indefinite one? Why can you disreguard the arbitary constant?
He actually got the indefinite wrong, but yes this is what you should have gotten.
Ok I got (250/2 + 175/2 +24 ) - (16/2 + 28/2 + 24) = 236.5 - 46 = 190.5 units of area?
Does that sound correct?
Thanks,
Ps, would y = -x^2 + 1 use the same method?
Thanks,
No, look at your orginal calculation, then look at HallsofIvy post. Do you see a difference?
He has misplaced a 3 for a 2, but I didn't use that in my calculation so 190.5 should be correct?
His was right, yours was wrong. You raised it to the 3rd power.
Ah I see what you mean.
So I got 151.497 units of area this time using the correct indefinite
Can you post your work? That's incorrect.
Edit: Looking at your previous post you probably forgot the x after the 24 again.
= [ 250/3 + 175 /2 +24] - [ 16/3 + 28/2 + 24 ]
= 194.83 - 43.33 = 151.497?
24x
Look at your steps very close.
Student100 said:
24x
I'm unsure on calculus, I understand as much that you multiply by the limits of x and then subtract it but with the x I do not know
We're past the calculus, you just got to look at your arithmetic, you are adding 24 instead of 24x or 24(5) and 24(2).
Sorry I see now.
As a final answer I got 223.499 now, I am really hoping that is correct
dc2209 said:
Sorry I see now.
That's right, you might want to practice keeping the answers in fraction forum, however. Just keep practicing.
  • · Replies 20 ·
  • · Replies 25 ·
