- #1
ssj2pizza
- 5
- 0
Block A is on a table and is connected by a pulley to block B.
Block A has weight Wa and block B has weight Wb. Once block B is set into downward motion, it descends at a constant speed. Assume that the mass and friction of the pulley are negligible.
Calculate the coefficient of kinetic friction between block A and the table top.
Express your answer in terms of some or all of the variables Wa , Wb, and g (the acceleration due to gravity).
fk=[tex]\mu[/tex]kn
I have gotten this hint (mastering physics problem):
In this problem, blocks A and B are in dynamic equilibrium; their velocities are constant. This means that the net force on each,F net , is equal to zero.
The tension is constant throughout the rope. By setting the sum of the forces acting on both blocks A and B equal to zero, you should be able to obtain two different expressions for the tension in the rope. Set these equal to each other and solve for [tex]\mu[/tex].
I really don't know how to go about starting this. I know the equation above but don't know what to do with it. I feel like I need to know the acceleration. How would I find the tension?
Please help! Thanks!
