Finding the density of a block in two layers of liquids
The discussion revolves around calculating the density of a block floating at the interface of two liquids, with a layer of liquid density 800 kg/m^3 above water. The block is submerged 3/4 in water and 1/4 in the liquid, leading to a buoyancy equation that ultimately determines the block's density to be 950 kg/m^3. Participants clarify the application of Archimedes' principle, emphasizing that the upward buoyancy force from the upper liquid is valid as it exerts pressure on the entire surface of the block through the water. Misunderstandings about buoyancy forces and the block's positioning are addressed, reinforcing the importance of pressure distribution in fluid mechanics. The final consensus confirms the block's density as 950 kg/m^3, aligning with the conditions of the problem.
Akash47
A layer of liquid with density ##800~kg/m^3## floats on top of a volume of water. A block floats at the oil-water interface with ##3/4## of it in water and the rest of it in the liquid. What is the density of the block?
Buoyancy =##vρg## where ##v##= volume of the block, ##ρ##=density of liquid, ##g##=gravitational acceleration.
(maybe the solution)The block has displaced water of volume of ##3/4## times the block's volume, so buoyancy on it by water is ##3/4~vρ_wg## (##ρ_w##=density of water) which is acting upward.The block has displaced liquid of volume of ##1/4## times the block's volume,so buoyancy acting on it by the liquid is ##1/4~vρ_lg## (##ρ_l##=density of the upper liquid) which is acting upward.We assume downward as negative and upward as positive.The weight of the block is ##vρ_bg## where ##ρ_b##=density of the block.The block is in stating equilibrium,so
##3/4~vρ_wg+1/4~vρ_lg=vρ_bg## implies, ##3/4~v*1000*9.8~+1/4v*800*9.8= vρ_b*9.8##
So, ##ρ_b=950##.
Akash47 said:
So, ##ρ_b=550##.
If the density of the block would be smaller than the density of the oil, wouldn't the block float on the oil?
Different question: Where does a balance show a larger value measuring your weight: In your bathroom filled with air or if it is evacuated?
Oh,I got my fault.As I have got the density of the block less than the liquid,so the block should float on the surface but that's against the condition.Then the buoyancy force on the block by the upper liquid may be acting upward.Thus I get the density of the block is ##950~kg/m^3##(see the edited thread) and that may satisfy the condition mentioned in question.But if the liquid forces the block upward,then the bottom of the block should be in the liquid but it's bottom surface is in the water.Then how it's possible?
Let h represent the depth of the liquid and H be the thickness of the block. What is the liquid pressure at the top of the block? What is the water pressure at the bottom of the block? If A is the cross sectional area of the block, what is the liquid downward force on the top of the block? What is the water upward force on the bottom of the block?
Likes Akash47
That looks good
Akash47 said:
But if the liquid forces the block upward,then the bottom of the block should be in the liquid but it's bottom surface is in the water.Then how it's possible.
Image you are swimming in the ocean. You are floating, since the density of the salt water is higher than yours. But if you are at the beach you can stand in the water just with its level reaching e.g your knees. Although the density of the water is higher, you don't float, because the buoyancy force only is as high as the weight force of the displaced water. But you will weigh less by the volume of your legs below your knees multiplied by the density of the water (and the gravitational acceleration).
How is the oil pushing the block up when it only contacts the top and sides? (There is an answer.)
One needs to be a bit careful applying Archimedes' principle. It is only valid when the fluid can exert pressure on the entire surface of the body. E.g. consider a rubber suction cup stuck to the bottom of a tank.
It can be applied in this case since the oil exerts pressure on the water, and that pressure is transferred to the underside of the body by the water.
Likes gneill
Thanks to all of you for helping me specially Chestermiller and haruspex.:smile:
  • · Replies 23 ·
