Finding the divergence or convergence of a series
5 replies · 2K views
aimsanko
Ʃ ,n=1,∞, (2/n^2+n)
Does this series converge or diverge?
Im not sure how to start can i use the comparison test here?
You can begin by making sure you stated the problem you meant to state. Is that expression (2/n2)+n, which is what you wrote would mean, or 2/( n2+n)?
What have you tried? What are your thoughts about it?
its 2/((n^2)+n)
and I'm thinking it converges because you are adding an infinite amount of numbers that are continually getting smaller and smaller
aimsanko said:
its 2/((n^2)+n)
Both convergent and divergent series have an infinite number of terms that get smaller and smaller, so that observation is of no value. For example, do you know the p series
[tex]\sum \frac 1 {n^p}[/tex]
and for what values of p it converges or diverges?
Do you know how to use the comparison tests? What might you compare your series with and why?
if p is greater than 1 the series converges
im not very good at the comparison test and how to find what to cop are it to
The first step in a comparison test is to decide by examining your series whether you think it probably converges or diverges. This is usually decided by previous experience with previously analyzed series such as a p series. The next step depends on your expectation of convergence or divergence.
If you think your series might converge, try to find a larger series that you know does converge. Then you have a series smaller than a known convergent series so it converges.
If you think your series might diverge, see if you can find a smaller series that you know diverges. If your series if larger than a known divergent series, it must diverge.
Your problem has similarities to a p series about which you know convergence or divergence. So think about that.
