Finding the Domain of a Logarithmic Function f(x) = log_5(8 - 2x)
The discussion revolves around finding the domain of the logarithmic function f(x) = log5(8 - 2x). Participants explore different methods for determining the domain, including using inequalities and number-line approaches, while also considering related logarithmic functions.
  • Homework-related
  • One participant expresses uncertainty about starting the problem and mentions a preference for using a number-line method.
  • Another participant states that for a logarithmic function to return a real value, the argument must be greater than zero, leading to the inequality 8 - 2x > 0.
  • A participant derives the inequality and concludes that the domain is (-∞, 4), but later acknowledges confusion about the steps taken to arrive at this conclusion.
  • Some participants correct earlier claims about manipulating inequalities, emphasizing the need for careful handling of the inequality signs.
  • There is a discussion about finding the domain of a more complex logarithmic function, ln((x - 1)/((x - 3)(x + 5))), and the need to identify critical values and test intervals for positivity.
  • One participant expresses difficulty understanding the method involving critical values and the concept of sign alternation across intervals.
  • Another participant suggests that the approach to finding the domain should be consistent regardless of the logarithmic function being analyzed.
Participants generally agree on the requirement for the argument of a logarithm to be positive, but there is disagreement on the methods used to derive the domain and confusion about the implications of critical values and interval testing.
Some participants express uncertainty about the mathematical steps involved, particularly regarding the manipulation of inequalities and the interpretation of critical values. There is also mention of different methods being discussed by the professor, which may not align with the approaches taken in the thread.
Students seeking to understand how to find the domain of logarithmic functions, particularly through the use of inequalities and number-line methods, may find this discussion helpful.
RidiculousName
I need to find the domain of f(x) = log5(8 - 2x).
I am not sure if I could find this by doing a inequality equation, but I think my professor wants us to do it on a number-line anyway. I'm sorry, but I am not sure where to start.
In order for a log function to return a real value, for:
$$f(u)=\log_a(u)$$
We require:
$$0<u$$
So, what inequality do we obtain from the given function?
$$f(u)=\log_a(u)$$
We require:
$$0<u$$
8 - 2x > 0
-2x > 8
x > 8/-2
x > -4
so the domain is (-$$\infty$$, 4)
I'm trying to figure out how to do it via the number-line method though. I need to do it that way because otherwise I can't find the domain of stuff like, $$y = ln\frac{x - 1}{(x - 3)(x + 5)}[/math]
RidiculousName said:
8 - 2x > 0
This is correct.
-2x > 8
This is not correct...if you are going to subtract 8 from both sides of the inequality, then you want:
$$-2x>-8$$
What I would have done is to add \(2x\) to both sides to get:
$$8>2x$$
Both approaches lead to:
$$x<4$$
In interval notation:
$$(-\infty,4)$$
This is what you eventually wound up with, but you got there from:
$$x>-4$$
and the end result does not follow from this.
To draw the solution on a number line, place an open circle at 4 (open circle because the inequality is strict), and shade to the left of that point.
MarkFL said:
This is correct.
$$-2x>-8$$
$$8>2x$$
$$x<4$$
$$(-\infty,4)$$
$$x>-4$$
Whoops! Thank you, I had gotten the answer from my professor beforehand. There should be a way to figure out the problem without using an inequality though. That is what I am trying to understand how to use. I know it involves a number-line and, it seems like, you guess at possible values for x. For example, you couldn't find the domain of $$y = ln\frac{x - 1}{(x - 3)(x + 5)}$$ just by using inequalities right? I am trying to figure out how to find the domain of a logarithm like that. The approach should work regardless of whether you use this or the first logarithm I posted. I am not just trying to figure out how to draw the domain on a number line. I am trying to figure out how to use a number line to find the domain.
For that function, we would set:
$$\frac{x-1}{(x-3)(x+5)}>0$$
To solve this, we need to find all of the roots of the numerator and denominator and list these as our critical values:
$$x\in\{-5,1,3\}$$
Because all of these roots are of odd multiplicity (the factors from which we obtained these roots are raised to an odd exponent, in this case all are to the first power), we know the sign of the expression will alternate across these critical values, and so we need only test one value of \(x\) in one of the resulting subdomains. For simplicity, I would choose \(x=0\) from the subdomain \((-5,1)\), and we find the expression is positive for that value of \(x\), and so that subdomain is part of the solution. And so the solution to the inequality, in interval notation, is:
$$(-5,1)\,\cup\,(3,\infty)$$
If you are more comfortable with testing a value in each subdomain, then you can do that...it's just less work if we realize the sign will alternate and simply test one.
And so the above is the domain of the function:
$$y(x)=\ln\left(\frac{x-1}{(x-3)(x+5)}\right)$$
$$x\in\{-5,1,3\}$$
It looks like I'll need to get help from my professor with this one. Thank you anyway. I'm just really having a hard time understanding what you're saying. Also, it seems like you're going over a method that relies on the factors of the roots being raised to odd exponents, which, I think, isn't what my professor was discussing. I really have no idea about most of what you're saying anyway. Like, how do you know [1, 3] isn't part of the domain? What is a critical value? What do you mean the sign will alternate?
Let's take a look at a graph of the expression which is the argument for the natural log function:
$$y=\frac{x-1}{(x-3)(x+5)}$$
The critical values are values for which either the numerator or denominator are zero (roots) and as I stated, these are:
$$x\in\{-5,1,3\}$$
These 3 critical values will divide the real numbers into 4 intervals, which are shaded in the diagram above. These intervals are:
$$(-\infty,-5)$$ shaded in orange
$$(-5,1)$$ shaded in red
$$(1,3)$$ shaded in green
$$(3,\infty)$$ shaded in blue
Now, let's forget about the multiplicity of the roots, and choose a test value from each of the 4 intervals, and look only at the signs (positive + or negative -) of the factors in the expression
In this interval, let's choose \(x=-6\) and so the signs of the 3 factors are:
$$\frac{(-)}{(-)(-)}=-$$
The expression is negative in this interval, and so it is not part of the solution, since we require the overall expression to be greater than zero, or positive.
In this interval, let's choose \(x=0\) and so the signs of the 3 factors are:
$$\frac{(-)}{(-)(+)}=+$$
The expression is positive in this interval, and so it is part of the solution.
In this interval, let's choose \(x=2\) and so the signs of the 3 factors are:
$$\frac{(+)}{(-)(+)}=-$$
The expression is negative in this interval, and so it is not part of the solution.
In this interval, let's choose \(x=4\) and so the signs of the 3 factors are:
$$\frac{(+)}{(+)(+)}=+$$
Do you see how the sign of the expression alternated over each interval?
And so the solution to the inequality:
is the union of all the intervals we found to be part of the solution:
And this then is the domain of the function:
