Finding the drift speed of a conduction electrons
The discussion revolves around calculating the drift speed of conduction electrons in a copper wire with varying diameters. The problem specifies a current density calculation using the formula v = j/nq, where the current density J2 was determined to be 402.5 A/m². The calculated drift speed for section 1 was found to be 7.41e-9 m/s, which was deemed incorrect by the original poster. Participants suggested potential errors, including a possible misprint in the voltage measurement, which might have been intended as millivolts instead of microvolts.
  • Understanding of electric current and charge carriers
  • Familiarity with the concepts of current density and drift velocity
  • Knowledge of the properties of copper, specifically resistivity (ρ = 1.72e-8 Ω·m)
  • Ability to manipulate equations involving electric potential and current
  • Review the derivation of drift velocity equations in solid-state physics
  • Investigate the impact of measurement units on electrical calculations
  • Examine common pitfalls in current density calculations
  • Explore practical applications of drift velocity in electrical engineering
Students studying electromagnetism, electrical engineers, and anyone involved in circuit design or analysis who seeks to understand the behavior of conduction electrons in conductive materials.
Omar FTM
The figure shows wire section 1 of diameter 4R and wire section 2 of diameter 2R, connected by a tapered section. The wire is copper and carries a current. Assume that the current is uniformly distributed across any cross-sectional area through the wire's width. The electric potential change V along the length L = 1.95 m shown in section 2 is 13.5 µV. The number of charge carriers per unit volume is 8.49x10^28 m-3. What is the drift speed of the conduction electrons in section 1?
v = j/nq
j=E/p = v/pL
I got J2 using the provided v2 and p ( of copper = 1.72e-8) and the L2
J2 = (13.5e-6)/(1.72e-8)(1.95) = 402.5 A/m^2
Then I used the relation between the two sections > J1A1 = J2A2 >>> J1(0.25Pi 4^2 ) = J2(0.25Pi 2^2) >>> j1 = 100.625 A/m^2
The drift speed of sec 1 would be >>> V1 = J1 / nq = 100.625/(8.49e28)(1.6e-19) = 7.41e-9 m/s ( which was a wrong answer ) what is my mistake ?
I don't see any errors. Be sure that you are using the values for n and ρ from your textbook rather than from the internet. The values could vary a little depending on the source of information.
I double checked my p and n , they are correct ( from the book (copper = 1.72e-8 ) , n from the question itself = 8.49x10^28 ) , but it's still telling me that my answer is wrong :(
I still can't find any error in your calculation. Maybe we're overlooking something that someone else will catch.
Any one ? :)
I am not real familiar with this kind of problem, but the math looked right. I did find an example on Wiki (under "Drift Velocity"), and because of the negative charge of an electron, the result came out to be negative. That's the only possibility I can come up with.
That's a thought. But speed is the magnitude of velocity, so I would think the answer should be positive. Anyway, thanks for the input, Tom.
Yep, good point.
Maybe, they meant mV instead of μV. It was a wire almost 2 m long!
Yes, could be. I had noticed the current density and drift speed were coming out very small. For j = 400 A/m2 and a wire of cross-sectional area 0.5 mm2, the current is only 0.20 mA.
I get your point , but this is how the question is :D
I think that I won't be able to solve it ...
Yes, the set-up and data for such a practically usual problem should be "real" , with a common voltage source and voltage measurable with a common voltmeter, multimeter. The smallest range of a common multimeter is 100-200 mV.
@Omar FTM Your solution is correct. It is quite possible that it was a misprint in the text of the problem.
Tried answering using V as mV instead of micro V , still wrong :(
It is also possible that the problem writers made some mistake. It happens quite often.
17K
11K
10K
