Finding the EMF Generated by a Solenoid
  • Thread starter Thread starter exitwound
    Emf Solenoid
11 replies · 3K views · last reply
exitwound
This is not a homework problem due. It's practice. I have the answer of .198mV. I don't know how to get it.
[tex]\phi_b = \int \vec B \cdot d\vec A[/tex]
[tex]E = -\frac{d\phi_b}{dt}[/tex]
The magnetic field due to the solenoid is:
[tex]\mu_o i N[/tex]
[tex](1.26x10^{-6})(1.28 A)(85400 turns/m) = 1.37x10^{-1} T[/tex]
The flux through the circular loop is:
[tex]\phi_b = \int \vec B \cdat d\vec A[/tex]
[tex]\phi_b = BAcos 0 = BA[/tex]
[tex]B = 1.37x10^{-1}[/tex] [tex]A=6.8x10{-3}[/tex]
[tex]\phi_b = BAcos 0 = BA = (1.37x10^{1})(6.8x10^{-3})= 9.34x10^{-4} Wb[/tex]
To find the EMF induced:
I don't know where to go from here. How do I relate that 212rad/s to the problem?
Try putting I=I0sin(ωt) to get the magnetic field.
Then use Φ=NBA
and then use E=-dΦ/dt
So instead of using
[tex]B=\mu_o i_o N[/tex] we use:
[tex]B=\mu_o i_osin(\omega t)N[/tex] which leads to
[tex]\phi = BA = \mu_o i_osin(\omega t)NA[/tex]
[tex]E = -\frac{d}{dt}\mu_o i_osin(\omega t)NA[/tex]
[tex]E = -\mu_o i_oNA\frac{d}{dt}(sin(\omega t))[/tex]
Is this how you meant? I think I'm lost.
exitwound said:
So instead of using
right yes and what is d/dt(sinωt) ?
exitwound said:
As far as I can tell, (cos t)(ω)? Maybe??
So then
[tex]E=\mu_0 I_0 NBA \omega cos(\omega t)[/tex]
so what is the amplitude?
The amplitude of the wave is 1.28 at maximum. But I don't know what that gets me.
no that is for the current
What is the amplitude of E?
The amplitude is equivalent to the maximum point on the wave that a wave equation describes.
Remember that cosine (and indeed sine) functions vary between -1 and 1, so the maximum cos value you can get is 1.
So what is the maximum that E can be in that equation?
(I think we have a typo. There shouldn't be a B in the equation, should there?)
Would it be: [tex] E=\mu_0 I_0 NA \omega[/tex]
because cos (ωt)=1?
because cos (ωt)=1?
Yes the B should be there.
so the amplitude would be
[tex]E= \mu_0 I_0 NBA\omega[/tex]EDIT: sorry you are right, it is [itex]E=\mu_0 I_0 NA \omega[/itex]
