Finding the expression of the bullet's speed, vB
  • Thread starter Thread starter lmc489
    Expression Speed
25 replies · 14K views
lmc489
You have been asked to design a "ballistic spring system" to measure the speed of bullets. A spring whose spring constant is k is suspended from the ceiling. A block of mass M hangs from the spring. A bullet of mass m is fired vertically upward into the bottom of the block. The spring's maximum compression d is measured.
Find an expression for the bullet's speed vB
So basically i started with
Ki + Ui = Kf + Uf
and then manipulated adding in the equation for the spring constant, k
and ended up with:
rad[(2Mg +m)k/m)] * d but its totally wrong
help please!
So the spring is extended holding the mass of the block (so the tension spring force is pulling the block up) - is the block going to move far enough that the spring is neutral or in compression?
I would think that the block is going to far enough that the spring compresses right??
That would make it complicated - sorry i just noticed this is a homework question not a real experiment. So you cna probably assume that the spring is massless and is in tension all the way.
so how would i go about finding the expression for the bullet's speed?
Conservation of energy.
Start = gravitational potential energy of block (Mgh) and stored spring energy (1/2 kx^2) + ke of the bullet (1/2mv^2)
End = more potential energy of block Mg(h+distance moved), less spring energy 1/2 k (x-distance moved)^2 + no ke of the bullet.
Be careful of the signs, think about which energy is increased or decreased.
I'm also working on this problem. I don't understand why energy is conserved, because isn't this an inelastic collision, in which some kinetic energy must be lost?
You can use energy conservation for the last part of the problem - once the bullet has finished embedding itself in the block (though bear in mind that the bullet ends up embedded in the block, so the initial collision must be inelastic, as you say).
Something else is conserved as well when the collision actually takes place, which you always need to take into account when doing a ballistic pendulum-style problem.
Right, conservation of momentum sets up the equation: mVb=(m+M)Vf, where Vf is the final velocity of the block w/ embedded bullet.
And for the energy conservation part, I have this:
.5mVb^2 + Mgy + .5kx^2 = Mg(y+d) + .5kd^2
I'm confused about the spring. Initially it has a potential elastic energy, but I don't understand how the distance (x) relates to the distance (d) that it moves.
If I can get the energy conservation right, then I can just substitute in from the momentum equation.
What do the letters 'd' and 'x' represent in each context?
The problem states that d is the distance the the spring compresses when the bullet hits it, and x is what I'm unsure of, but I think it is the amount that the spring is already stretched because of mass M hanging from it.
The simplest way woul dbe to define the spring extention to be 0 at the top of it's motion when the bullet hits. Then spring extention = distance moved (except for signs)
"The simplest way woul dbe to define the spring extention to be 0 at the top of it's motion when the bullet hits. Then spring extention = distance moved (except for signs)"
And in that case the initial elastic spring force (.5ks^2) = 0?
No the initial spring force would be = the weight of the block.
the initial spring energy would be 1/2 k x^2 and the final spring energy = 0.
Ok, so the initial spring force doesn't matter right?
And potential energy of the block, since we aren't given the height the block is above the ground, how does that get involved? I'm pretty lost . . .
Just using conservation of energy. You only care about changes in energy - you can pick any starting level, after all when you do the potential energy of a block you don't consider the altitude !
So to make life easy we will set the potential energy of the block when it is hanging down to be zero, and the spring energy at the highest point to be zero. Then we only have one distance term to worry about.
So initially we have:
ke bullet + pe block(=0) + spring energy (=1/2 kx^2)
Afterward we have:
ke bullet(=0) + pe block (mgx) + spring energy(=0)
That makes all the bullet ke + spring energy -> block pe.
A bit of simple rearrangemnt (watch the signs) and you are set.
Grateful for your help, and the problem is clearing up in my mind. One more thing about signs though. I thought that energy values were scalars and not vectors. So signs only come into play when there is a vector in the equation? Are the only variables affecting the signs the velocity of the bullet, g, and x?
Scalers have signs. If you slow down your ke change is negative.
It is harder to get wrong than in a forces/vector calculation - that's why conservation of energy is often a good appraoch.
i have question on the same problem.
does this mean the answer is sqrt[(2Mgx - kx^2)/m]
can someone please check my answer thanks so much
Afterward we have:
Are the height for the gravitational potential energy and the change in position for the spring energy the same? How come?
Thank you so much for your help.
should the PE of the block also include the mass of the bullet? is this an inelastic collision?
Probably should (although the mass of the bullet isn't very large)
so plugged in my answer to mastering physics and it doesn't work. can you tell me if this is right anwer?
Vbullet = sqrt[ (2(M+m) - kx^2) / m]
thanks so much, i really appreciate it, this is due tonight for me
Sorry just noticed a typo
I get V^2 = (2(m+M)gx - kxx)/M
What matters is the displacement from the equilibrium position. When the block was hung from the spring, the spring would have stretched - so that it was in a new equilibrium position. It's the displacement from this equilibrium position that matters.
