Finding the force of kinetic friction without a coefficient
The discussion centers on calculating the force of kinetic friction in a Fletcher's trolley system experiment. The known variables include a hanging mass of 0.100 kg, a sliding mass of 0.1553 kg, a distance of 0.398 m, and an acceleration of 1.01 m/s². The normal force was calculated to be 1.52 N, while the force of friction was determined to be 0.723 N using the equation Ffk = Mg - ma. The final goal was to find the coefficient of kinetic friction, μk, which can be calculated using μk = Ffk/Fn.
  • Understanding of Newton's laws of motion
  • Familiarity with free body diagrams
  • Knowledge of basic kinematic equations
  • Ability to calculate forces using F = ma
  • Learn how to derive equations for systems involving multiple masses
  • Study the concept of normal force in different scenarios
  • Explore graphical methods for analyzing forces and motion
  • Investigate the relationship between friction and surface materials
Students in physics courses, particularly those studying mechanics, as well as educators looking for practical examples of friction calculations in lab settings.
Her0
In a lab assignment we created a Fletcher's trolley system and were asked to calculate the normal force, the force of friction, and then create a graph of both to find the coefficient of kinetic friction.
So far, the variables I have are:
Hanging mass: 0.100 kg
Sliding mass: 0.1553 kg
Distance traveled by the sliding mass: 0.398 m
Time taken for the sliding mass to reach the ground: 0.89 s
Acceleration of the system: 1.01 m/s^2
Normal force: 1.52 N
Force of friction : Unknown
The acceleration of the system was found using the equation a=(2(d-vit))/t^2 which i simplified to a=2d/t^2 since vi was 0 m/s.
The normal force of the sliding object was found using Fn = mg
The force of friction would be calculated using Ffk = Fn*μk but I don't have μk.
As stated above, I tried using Ffk = Fn*μk but i didn't have all the variables.
Did you draw free body diagrams for each of the 2 blocks and then write equations to relate sum of the forces to acceleration for each block?
Okay so I tried doing that and essentially what I got was that Ffk = Mg - ma where Mg is the force of the hanging object and ma is the force of both masses of the system multiplied by the system's acceleration because Fnet = Fapp -Ffk.
I'm not used to working with systems. I would normally write separate equations for each block and then solve the two equations with the two unknowns. But I think your equation below makes sense.
Her0 said:
Ffk = Mg - ma
So I think you have everything you need to solve that equation, provided you rewrite Ffk in terms of the normal force. You know the masses and acceleration.
I did not know what Fapp was.
Edit: P.S. Welcome to Physics Forums.
Fapp was a formula for applied force which I used to derive my new formula for Ffk. Other than that, I now have everything I need to calculate the force of friction. Thank you!
Let me know what you get for a final answer. I always like to check my work.
So I subbed in the values resulting in the equation becoming Ffk = (0.100 kg(9.81m/s^2))-((0.100kg+0.1553kg)(1.01m/s)) which resulted in the answer being 0.723 N rounded to three significant digits.
Okay, that looks right. For some reason, I was thinking that the goal of the problem was to find the coefficient of friction. And as I now re-read the problem statement, finding the coefficient of friction is indeed the final question. I just don't know why you would need to create a graph to do that.
It's just a procedure my professor told us to use even though we could find the coefficient using μk = Ffk/Fn after Ffk was determined. Either way, thanks again for the help.
  • · Replies 20 ·
  • · Replies 16 ·
