Finding the force on a cord from a pulley
9 replies · 3K views · last reply
Johno123
(Mentor note: moved from General Eng hence not homework template)
Diagram of a pulley system: string L runs from a loop at upper left down to a pulley at the centre, string R (upper part) runs from the pulley to a loop at upper right at angle φ, and string R (lower part) hangs vertically from the pulley to a rectangular mass below. Angle θ is marked between string L and a horizontal line.
This is the given scenario. I'm trying to find the 'String R (lower part)' force. I know every other variable (the angles, string L and string R and the Rectangle is a mass m). Any help would be appreciated!
  • Diagram of a pulley system: string L runs from a loop at upper left down to a pulley at the centre, string R (upper part) runs from the pulley to a loop at upper right at angle φ, and string R (lower part) hangs vertically from the pulley to a rectangular mass below. Angle θ is marked between string L and a horizontal line.
Is that a mass m hanging from String R?
Yes sorry I forgot to put that in! Just fixed it.
Hi again.
If this is homework, we have a section called Homework Help, to which it can be moved.
Is it homework?
It has an outline to follow, which gives you a much better responses from people who will guide you to a solution.
256bits said:
Hi again.
Is it homework?
No its not homework. I'm doing some study ahead for my course next year and I wanted some help with this question.
So what have you tried so far?
It is difficult to tell where you are having trouble without showing some of your calculations and equations.
That's confusing to me.
It looks like a trivial question because string R's lower segment just holds up mass M.
Yet you titled your thread :
"force on a cord from a pulley"
If nothing is in motion that seems straightforward to find.
Have you drawn a free body diagram of that pulley showing the forces on it? Since nothing is moving you can make believe everything is glued together.
That was probably a hint rather than a question.
It like be interesting to see the whole problem statement.
Do you know how the tension in string R in the upper part compares with the lower part? If you are studying ahead, this is an important part of your learning.
