Finding the Indefinite Integral Extension Questions
12 replies · 3K views
CaptainK
∫8x3e-cos(x4+4)sin(x4+4)dx
Let u = cos(x4+4)
I know the answer does not have the sin in it and only the e remains, because when the integral is found e stays unchanged.
I could find somewhere online to calculate it, but I want to know how to do it, because questions like this will be on the final exam.
Let u = cos(x4+4)
You have the correct u substitution. Now use it. What's du?
So I've found du and put it into the form
∫udv = uv - ∫vdu
so for v I have 8x3
du = -sin(4x3) dx
dv = 24x2 dx
Which gives me
∫cos(x4+4)24x2dx = cos(x4+4)8x3 - ∫8x3(-sin4x3) dx
But I feel like I'm going down the wrong path, especially since the e isn't present
You are going down the integration by parts path. It's not the right way to go. Why do you think du=(-sin(4x^3))dx?
So using substitution
du = sin(x4+4)
because cos converted to sin doesn't change its sign, I thought it did but its for converting from cos to sin.
t = u
∫f'(g(x))g'(x) dx = ∫f'(t) dt/dx = ∫ f'(t)dt = f(t) + C
= f(g(x)) + C when substituting back in
f(x) = original equation and
t = u = cos(x4+4)
du = sin(x4+4)
t = u
t = u = cos(x4+4)
df(x)=f'(x)*dx. f(x) here is cos(x^4+4). What is df(x)?
so f(x) = cos(x4+4)
then
f'(x) = sin(x4+4) + 4x3
which gives
∫cos(x4+4) +4x3 *sin(x4+4) + C
CaptainK said:
so f(x) = cos(x4+4)
then
which gives
I'd suggest you review the chain rule. If f(x)=cos(x^4+4) then the derivative f'(x) is not what you wrote. Give it another try. Tell me what the chain rule says.
Chain Rule states
dy/dx = dy/du * dx/du
8∫x3∫e-cos(x4+4)∫sin(x4+4)
8∫x4/4∫e-cos(x4+4)∫cos(x4+4)+4x3
CaptainK said:
Chain Rule states
Stop worrying about the integral for a while. You are having trouble differentiating f(x)=cos(x^4+4). Try and get that right first.
Finding the derivative of cos(x4+4)
I got -4x3sin(x4+4)
Do I then follow the formula above with f(x) and t and then solve for the Integral.
I got -4x3sin(x4+4)
Ok, you've got the derivative. If you take u=cos(x^4+4), that means du=(-4x^3)sin(x^4+4)dx. Now you should be able to turn the integral into
[tex]C \int e^{-u}du[/tex]
where C is a numerical constant. This is u-substitution.
