Finding the Indefinite Integral Extension Questions
The discussion revolves around finding the indefinite integral of the function ∫8x^3e^(-cos(x^4+4))sin(x^4+4)dx. The correct approach involves using the substitution u = cos(x^4+4), leading to the derivative du = -4x^3sin(x^4+4)dx. Participants emphasize the importance of correctly applying integration techniques, particularly the chain rule and integration by parts, while clarifying that the sine term will not appear in the final answer. The conversation highlights the need for a solid understanding of derivatives and substitution to solve the integral effectively. Mastery of these concepts is deemed essential for success in upcoming exams.
CaptainK
∫8x3e-cos(x4+4)sin(x4+4)dx
Let u = cos(x4+4)
I know the answer does not have the sin in it and only the e remains, because when the integral is found e stays unchanged.
I could find somewhere online to calculate it, but I want to know how to do it, because questions like this will be on the final exam.
Let u = cos(x4+4)
You have the correct u substitution. Now use it. What's du?
So, what do you get after that u substitution??
So I've found du and put it into the form
∫udv = uv - ∫vdu
so for v I have 8x3
du = -sin(4x3) dx
dv = 24x2 dx
Which gives me
∫cos(x4+4)24x2dx = cos(x4+4)8x3 - ∫8x3(-sin4x3) dx
But I feel like I'm going down the wrong path, especially since the e isn't present
You are going down the integration by parts path. It's not the right way to go. Why do you think du=(-sin(4x^3))dx?
So using substitution
du = sin(x4+4)
because cos converted to sin doesn't change its sign, I thought it did but its for converting from cos to sin.
t = u
∫f'(g(x))g'(x) dx = ∫f'(t) dt/dx = ∫ f'(t)dt = f(t) + C
= f(g(x)) + C when substituting back in
f(x) = original equation and
t = u = cos(x4+4)
du = sin(x4+4)
t = u
t = u = cos(x4+4)
df(x)=f'(x)*dx. f(x) here is cos(x^4+4). What is df(x)?
so f(x) = cos(x4+4)
then
f'(x) = sin(x4+4) + 4x3
which gives
∫cos(x4+4) +4x3 *sin(x4+4) + C
CaptainK said:
so f(x) = cos(x4+4)
then
which gives
I'd suggest you review the chain rule. If f(x)=cos(x^4+4) then the derivative f'(x) is not what you wrote. Give it another try. Tell me what the chain rule says.
Chain Rule states
dy/dx = dy/du * dx/du
8∫x3∫e-cos(x4+4)∫sin(x4+4)
8∫x4/4∫e-cos(x4+4)∫cos(x4+4)+4x3
CaptainK said:
Chain Rule states
Stop worrying about the integral for a while. You are having trouble differentiating f(x)=cos(x^4+4). Try and get that right first.
Finding the derivative of cos(x4+4)
I got -4x3sin(x4+4)
Do I then follow the formula above with f(x) and t and then solve for the Integral.
I got -4x3sin(x4+4)
Ok, you've got the derivative. If you take u=cos(x^4+4), that means du=(-4x^3)sin(x^4+4)dx. Now you should be able to turn the integral into
C \int e^{-u}du
where C is a numerical constant. This is u-substitution.
  • · Replies 27 ·
