Finding the Inverse of a Circuit: Step-by-Step Guide for Basic Laplace Questions
  • Thread starter Thread starter Desii
    Laplace
The discussion revolves around finding the inverse of a circuit in the context of Laplace transforms, specifically determining the voltage v(t) after a switch moves to a different position, detaching from a battery.
  • Mixed
  • Participants discuss the process of finding the inverse of a Laplace transform, with one participant expressing uncertainty about their approach and seeking verification of their work. Others question the terminology used, particularly the phrase "inverse of a circuit," and seek clarification on what is meant by this.
The discussion is ongoing, with some participants providing insights into the Laplace transform process while others are exploring different interpretations of the problem. There is no explicit consensus, but guidance has been offered regarding the inverse of the Laplace transform.
Participants are navigating the specifics of the circuit's behavior after the switch operation and the implications of the Laplace transform in this context. There is a noted lack of clarity regarding the original poster's intentions and definitions.
Desii
I'm stuck on finding the inverse of this circuit. Can anyone please check my work, In this circuit you are suppose to find v(t) when switch moves to point 2 ( meaning deattached from battery).
http://postimage.org/image/z9acdes87/
The inverse of 1/s is the unit step.
That answer doesn't explain anything about the circuit, So I did it wrong, can you please check my work
It would help if you tell us what you mean by the "inverse of a circuit"! In your attachment, you seem to be trying to find the inverse of the Laplace transform and lurflurf told you exactly how to do that.
As for "checking your work", you are fine up until finding the inverse of the Laplace transform [24C/(RC+2)] (1/s). That has a lot to do with finding the current, i. I don't know what you mean by "has to do with the circuit". What more are you trying to find?
