Finding the maximum point of a function
5 replies · 2K views · last reply
AStaunton
trying to show that the maximum of a certain function is [tex]\sqrt{\frac{2kT}{m}}[/tex].
The function in question is:
[tex]f(v)=4\pi(\frac{m}{2\pi kT})^{\frac{3}{2}}v^{2}e^{-\frac{mv^{2}}{2kT}}[/tex]
so to do this find df/dv and set that = 0 and the value for v will be the v_max:
[tex]\frac{df}{dv}=2ve^{-\frac{mv^{2}}{2kT}}-\frac{2kT}{m}e^{-\frac{mv^{2}}{2kT}}=e^{-\frac{mv^{2}}{2kT}}(2v-\frac{2kT}{m})=0[/tex]
now divide out the (2v-2kT/m) term leaves:
[tex]e^{-\frac{mv^{2}}{2kT}}=0[/tex]
take natural log of both sides:
[tex]-\frac{mv^{2}}{2kT}=1\implies v=\sqrt{-\frac{2kT}{m}}[/tex]
The answer I found was wrong by a minus sign, can anyone tell me where along the line I somehow created this extra minus? Also, I'm not sure if it is completely kosher to divide out the (2v-2kT/m) term as I did, so also please give clarification on this.
And final question; if the dividing out the (2v-2kT/m) is a correct method to solve this problem, should it also be possible to divide out the exponential term instead...that is when I'm at this point:
[tex]e^{-\frac{mv^{2}}{2kT}}(2v-\frac{2kT}{m})=0[/tex]
should I be able to divide out the exponential term and then also expect to find an identical value for v_max, ie. solve the following for v and this will be my v_max:
[tex]2v-\frac{2kT}{m}=0\implies v=\frac{m}{kT}[/tex]
clearly this is not the value for v_max that was stated in the start of the problem...so clarity on this is much appreciated
Hi AStaunton! :wink:
Sorry, but this is completely wrong :redface: …
your product rule derivative is wrong,
ex is never 0 (unless x = -∞),
and yes of course you can't discard that (wrong) bracketed term.
Start again, carefully. :smile:​
OK...I think this is the correct derivative now, (noting that I did not include the constant multiplying term as this is going to divide out anyway):
[tex]\frac{df}{dv}=2ve^{-\frac{mv^{2}}{2kT}}-\frac{mv^{4}}{2kT}e^{-\frac{mv^{2}}{2kT}}=e^{-\frac{mv^{2}}{2kT}}(2v-\frac{mv^{4}}{2kT})=0[/tex]
at this point, my idea of dividing out one or other of the terms and solving for v was the only trick I had...and you say this is incorrect. any advice on how to proceed is appreciated
Hi AStaunton! :smile:
nope, still wrong! :redface:
you needed to use the chain rule as well as the product rule …
you can't just multiply by the whole of that exponent. :wink:
(And when your bracket is correct, you know that it has to equal zero.)
thanks.
Is it just a peculiarity of the exponential function that I had to focus on the bracketed term..
ie. in general it is OK to divide out either of the terms to get a valid answer for v?
of course, really what this is doing is finding the roots of the equation df/dv..
AStaunton said:
… in general it is OK to divide out either of the terms to get a valid answer for v?
In general, if AB = 0, then both A = 0 and B = 0 will be solutions.
The only difference in this case is that A can't be 0. :wink:
