Finding the number of revolutions
  • Thread starter Thread starter aligass2004
    Revolutions
The discussion focuses on calculating the torque and the number of revolutions of a compact disk starting from rest. The torque applied to the disk is found to be approximately 1.944 x 10^-3 Nm using the formula t = I(delta w/delta t). For the number of revolutions before reaching full speed, the user initially calculated 283.453 but was advised to convert this value to radians and check the calculations for accuracy. The key equations involve angular acceleration and the relationship between angular displacement and time. Accurate calculations are essential for determining the correct number of revolutions.
aligass2004
Starting from rest, a 12cm diameter compact disk takes 2.7s to reach its operating angular velocity of 2005rpm. Assume that the angular acceleration is constant. The disk's moment of inertia is 2.5 x 10-5 kgm^2.
a.) How much torque is applied to the disk?
b.) How many revolutions does it make before reaching full speed?
t=I(alpha)
For part a I used t = I(delta w/delta t). I found w by finding the frequency (33.417rev/s), and then I plugged f into w = (2pi radians)f to get 209.965. I then found torque to be 1.944 x 10-3 Nm. I am unsure of how to solve for part b.
I tried using delta theta = wi (delta t) + 1/2(alpha)(delta time)^2. I got 283.453, but that wasn't right.
Divide by 2(pi) to put your answer in radians
  • · Replies 18 ·
