Finding the range of a projectile at an angle
The discussion revolves around calculating the range of a projectile fired from a height of 2 meters at a 30-degree angle with an initial velocity of 800 m/s. The initial vertical velocity is determined to be 400 m/s, and the projectile's motion is affected by gravity, which is approximated at -10 m/s² for simplicity. Participants clarify that the time of flight must account for the projectile descending to ground level, not the same height from which it was launched. A quadratic equation is used to solve for the time of flight, leading to a more accurate calculation of the horizontal range. The final range is determined by multiplying the horizontal speed by the calculated time of flight.
Precepts
Calculate the range if a sniper stands and raises his barrel to an angle of 30 degrees above the horizontal with the end of the barrel 2.0 m above the ground. The muzzle velocity of his rifle is 800m/s.
Known variables:
U = 800ms^-1
Uv = 400m/s
Uh = 692.8m/s
a = -9.8m/s
V = u + at
v^2 = u^2 + 2as
s = ut + 1/2at^2
Sh = Uh x t
In order to find t, I doubled the time to the apogee:
Vv = u + at
0 = 400 x -9.8t
9.8t = 400
t = 40.8 sec. (apogee)
Therefore time of flight = 81 sec. (This is obviously wrong... using this in the range equation gives too large a number). So I don't know where to go from here. The launching at an angle + a height is confusing me, I'm just not seeing it.
Known variables:
U = 800ms^-1
Uv = 400m/s
Uh = 692.8m/s
a = -9.8m/s
V = u + at
v^2 = u^2 + 2as
s = ut + 1/2at^2
Sh = Uh x t
Vv = u + at
0 = 400 x -9.8t
9.8t = 400
Just where did you want to know the range?
To a point also 2m off the ground [ that's what you have been working towards ] or to a point on the ground, ie 2m below the launch height. [given the speed involved this has to be about 2√3 metres further than what you were going to calculate.
Right, I'm not sure where the 2m comes into it. I want to know the horizontal range for when it hits the ground. I'm not sure how to go about doing this. Thanks.
When you chose to (inaccurately) double the "time to apogee", you were using the principle that a projectile takes just as long to go up as it takes to come down. That is true only if the projectile comes down to the same height as it left from.
The barrel of the gun was 2m above the ground - the bullet comes all the way back to ground level - so you said.
By the way 40.8 x 2 is not equal to 81
Yes, I understand this. Can you calculate to include the 2m?
Or at least show me how...?
By "can you calculate to include the 2m" were you asking whether it could be done or were you asking whether I could calculate it?
To the latter - yes I can.
To the former - yes it can be.
Can you calculate the time taken for a ball to reach the ground when thrown up from the roof of a 20m building? (that is a general question, but if you want some practice, let's say it was thrown at 20m/s at an angle of 30o with the horizontal. To make the calculations really easy, take g = 10)
To allow for the 2m height, the final vertical displacement of the bullet is 2m down.
Thanks, could you work the solution for me? I just want to see how you did it.
Edit - Nvm, I solved it.
I will use g = 10 for simplicity. You can do it "properly" using g = 9.8
Initial velocity 800 m/s means initial vertical is 400 m/s up.
line up the variables - I use v,u,a,s,t
take up as positive:
u = 400
v = not wanted
a = -10
s = -2
t = ?
I want the motion equation without v ... s = ut + 0.5 at2
-2 = 400t - 5t2
so 5t2 - 400t - 2 = 0
use general solution to quadratic equation
t = [400 ±√(160000 + 40)]/10
t = [400 ±√160040]/10
t = [400 ± 400.05]/10
t can't be negative so
t = 800.05/10 = 80.005
range is thus Horizontal speed times 80.005 ie 400√3 x 80.005 = whatever
u = 400
v = not wanted
a = -10
s = -2
t = ?
-2 = 400t - 5t2
Thanks for that, I didn't use the quadratic equation and got the correct answer. I forgot about it.
