Finding the shortest distance from a point to the plane
Specter
Find the shortest distance from P(-4,2,6) to the plane 2x-3y+z-8=0.
##|proj_\vec n \vec PQ|=|(\frac {\vec PQ \cdot \vec n} {\vec n \cdot \vec n})| |\vec n|##
I kind of had to guess some steps because it was done differently in my lesson and I couldn't figure it out that way. Am I on the right track?
The normal is ##\vec n =(2,-3,1)##
Find another point on the plane, let x=0 and y=0
2x-3y+z-8=0
2(0)-3(0)+z-8=0
z=0
Another point on the plane is Q(0,0,8).
I have to find the direction of ##\vec {PQ}##
##\vec {PQ}=\vec Q - \vec P##
=(0,0,8)-(-4,2,6)
=(4,-2,2)
To find the shortest distance, I think I would project ##\vec {PQ}## onto ##\vec n##.
=##|\frac {(4,-2,2) \cdot (2,-3,1)} {(2,-3,1) \cdot (2,-3,1)}| |(2,-3,2)|##
=##|\frac {(4)(2)+(-2)(-3)+(2)(1)} {(2)(2)+(-3)(-3)+(1)(1)}| |(2,-3,1)|##
=##|\frac {16} {14}| |(2,-3,1)|##
=##|\sqrt (\frac {16} {7}), (-\frac {24} {7}), (\frac {8} {7})|##
=##\sqrt (\frac {16} {7})^2 + (-\frac {24} {7})^2 + (\frac {8} {7})^2##
=##\sqrt \frac {256} {49} + \frac {576} {49} + \frac {64} {49}##
=##\sqrt \frac {896}{49}##
The shortest distance is ##\sqrt \frac {896}{49}##
Likes WWGD and Charles Link
I learned the formula ## d=\frac{|Ax_1+By_1+Cz_1+D|}{\sqrt{A^2+B^2+C^2}} ## and I get ## d=\frac{16}{\sqrt{14}} ##. With a little arithmetic, (your numerator is divisible by 7, and ## 896=64 \cdot 14 ##), your answer agrees with mine. And yes, your method works.
Likes Specter
Thanks! Do you know what that formula is called? That seems like an easier/quicker way to solve these problems.
Likes Charles Link
It's a fairly well-known result. It's simply the formula for the distance from a point to a plane in 3 dimensions. There is a 2-dimensional version of it for the distance from a point to a line in the x-y plane: ## d=\frac{|Ax_1+By_1+C|}{\sqrt{A^2+B^2}} ##.
Likes Specter
The formula is easy to derive.
The equation of the plane is Ax+By+Cz+D=0
The point P is (x1, y1, z1)
The unit normal vector of the plane is ##\vec n = (n_1, n_2, n_3) ##
ni = A/||n|| and ## ||n|| = \sqrt{A^2+B^2+C^2}##
Write the parametric equation of the line that is normal to the plane and goes through P.
x=x1-tn1
y=y1-tn2
z=z1-tn3
The magnitude of t is the distance along the line.
Q(x, y, z) is point of the plane. Substitute x, y, z into the equation of the plane and solve for t.
A(x1 - tn1)+B(y1 - tn2)+C(z1 - tn3)+D=0
##t=\frac{Ax_1+Bx_2+Cx_3+D}{An_1+Bn_2+Cn_3}##, but
##An_1+Bn_2+Cn_3=\frac{A^2+B^2+C^2}{||n||}=\sqrt{A^2+B^2+C^2}##
The shortest distance is the length of the normal line
##t=\frac{Ax_1+Bx_2+Cx_3+D}{\sqrt{A^2+B^2+C^2}}##
Likes Specter, Charles Link and Delta2
I tried solving it this way and got a bit of a different answer. Might be an obvious mistake but this is my first math course in a while!
##d= \frac {|A_x+B_y+C_z+D|} {\sqrt (A)^2+(B)^2+(C)^2}##
## d=\frac {|2(-4)+3(2)+1(6)-8|} {\sqrt (2)^2+(3)^2+(1)^2}##
##d=\frac {-4} {\sqrt 14}##
## B=-3 ## in this problem. You will get ## |-16|=16 ## for the numerator.
Likes Specter
Ah yes whoops... Thank you.
Likes Charles Link
  • · Replies 18 ·
