Finding the sum of finite terms of a Maclaurin series
The discussion centers on finding the sum of the first 10 terms of a Maclaurin series related to e^(ln2). The original poster struggles with identifying a constant ratio for the series and questions how the sum can approach 2 while the first 10 terms add up to approximately 1. Participants clarify that the series is missing the initial term of 1 from the exponential expansion, which explains the discrepancy. One user successfully uses Maple to compute the sum, while another shares their experience using Excel for the same purpose. The conversation highlights the convergence properties of the series due to the factorial in the denominator.
ohpoonet
Hi. Find the sum of the first 10 terms in the series:
1, (ln2)/1!, (ln2)^2/2!, (ln^3)/3!...
I guess the Maclaurin series, which is e^k = 1, k/1!, (k^2)/2!, (k^3)/3!...
In my case, k = ln2.
I tried to use the sum of the first n terms Sn = (u1(r^n -1))/(r-1). However I cannot find r because it is not constant.
I realize if you replace k with ln2, you get e^(ln2) = 2 = 1 + k/1! + (k^2)/2!...So the series approaches 2.
As a last resort I will go caveman style and add up all terms from 0-10. That's a lot of decimals, so if anyone can help, it will be appreciated.
Here's what Maple gives for the writing on the caveman's wall: 0.99999999952832752678
Interestingly close to 1. It also gives a formula for the sum of n terms in terms of an incomplete gamma function with parameter ln(2), which somehow I doubt is what you are looking for.
Haha thanks BUT,
Do you agree that the series approaches 2? after all, e^ln2 is 2. If so how can the first 10 terms add up to 1?
I never heard of Maple until now, it seems like an algebra application. My question is now, did you solve for S of 10? in this case, what did you use for r, the ratio? Or did it simply add up all the terms 'manually'?
Sorry but i don't know about Maple. I will research the gamma function though I do not think its the right direction.
More help will be great. Thanks in advance!
ohpoonet said:
Haha thanks BUT,
Sorry but i don't know about Maple. I will research the gamma function though I do not C
e^(ln(2)) may be 2, but your series doesn't start with the first term of the expansion of e^x. The '1' is missing. LCKurtz just added them up using Maple and didn't solve for anything.
ohpoonet said:
Haha thanks BUT,
Maple is a sophisticated and powerful mathematics program with many uses. It has no problem adding up lots of terms keeping many decimal places; that's all I did. As Dick has pointed out, the first term of 1 in the exponential expansion is missing from your series which is why it approximates 1. The fact that it is so close after 10 terms is due to the high rate of convergence caused by the factorial in the denominator.
Many schools have a license agreement for a student version of Maple. You can read about it at:
http://www.maplesoft.com/
Hi guys,
Thanks for the response. I understand now. I actually used MS excel to add up the terms. I also found out that in:
((xLNa)^n)/n!
the graph approaches a^x.
(For example i put x=2 and a=3 and found the sum of the first 9 terms approached 9.)
Just for thought.
Thanks again.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 48 ·
  • · Replies 17 ·
  • · Replies 38 ·
  • · Replies 17 ·
