MHB What Integer Values Satisfy the Equation xy^2=54 with Constraints?
  • Thread starter Thread starter chead9
The discussion focuses on finding integer values for x and y that satisfy the equation xy^2=54, with both x and y constrained to be less than 10. The equation can be rearranged to x=54/y^2, requiring y^2 to be a factor of 54 and a perfect square. The analysis reveals that y must be an integer between 3 and 10, leading to the conclusion that y=3 results in x=6. This solution meets all the specified constraints of the problem.
chead9
What are the possible values of y such that xy^2=54, x is less than 10, y is less than 10, and x and y are integers? How do I go about finding this answer?
Mathematics news on Phys.org
If both $x$ and $y$ have to be integers greater than 10, then what is the smallest value for $xy^2$?
I made a mistake in the post.. it was supposed to be x and y are both less than 10
Ah, okay...now we're in business. :)
I think I would start out by arranging the given equation as:
$$x=\frac{54}{y^2}$$
Now, if $x$ is to be an integer, then $y^2$ must be a factor of 54 and at the same time a perfect square. Can you think of any such numbers?
We have:
And since we require:
$$x<10$$
this means (also gven $y<10$):
$$\frac{54}{y^2}<10\implies 3\sqrt{\frac{3}{5}}<y<10$$
And since $y$ must be an integer, we should write:
$$\left\lceil3\sqrt{\frac{3}{5}}\right\rceil\le y<10$$
$$3\le y<10$$
We need a number $y^2$ which is a factor of 54 and is a perfect square...so looking at the prime factorization of 54, we find:
$$54=2\cdot27=2\cdot3^3=6\cdot3^2$$
Thus, we must have:
$$y=3\implies x=6$$
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
