Finding the Velocity of a BB on a Magnetic Linear Accelerator
To measure the velocity of a ball bearing accelerated by a magnetic linear accelerator, a slow-motion camera has limitations due to the track's length. Using photointerrupter devices spaced closely along the track can effectively capture the speed by measuring the time it takes for the BB to pass between them. Alternatively, a pendulum setup can be employed, where the BB's impact on the pendulum allows for kinetic energy calculations based on height changes. Both methods provide viable solutions for measuring velocity while the BB is still on the track. Exploring these technologies can enhance accuracy in speed measurement for magnetic linear accelerators.
Zystrophys
As is in the title, I am looking for a better way to measure the velocity of a ball bearing (actually only looking for speed) that has been accelerated by a magnetic.
If you don't know what a Magnetic Linear Accelerator is, then this link/video should help:
I already have some success with a slow motion camera, but my Accelerator is around 9 feet long, so keeping the all of it in the frame is very tough while also keeping the distance markers in focus.
Any ideas on what technology I could use?
Projectile velocities are usually measured with a chrongraph for ballistic data. Midway has one that works on sub-sonic projectiles for less than $US70. In the US: Gun shops that specialize in reloading supplies handle various kinds of chronographs.
You can also google for 'how to build a chronograph'.
Thanks. I was looking into that option.
The only issue that I also want to measure the velocity of the BB while its still on the track.
Welcome to the PF.
Depending on the geometry of the track for the BB, you may be able to use a closely-spaced pair of photointerrupter devices to measure the speed of the passing BB. You can use something as simple as a digital oscilloscope to capture the delta-time between the closely spaced interruptors (say 1cm apart), and calculate the speed from that. Or you could build a larger circuit that measures the speed at several places along the track, using pairs of photointerrupters at each location.
https://encrypted-tbn3.gstatic.com/...jg31uZbm3wBWp8X3y-_j8ttW90FY4EyEaxK4y8H2MbohA
An alternative would be with a pendulum. The BB embeds itself in the pendulum which swings up and pushes a marker that stays where it is pushed. Knowing the mass of the ball, pendulum and dimensions you can calculate the kinetic energy of the BB by measuring the potential energy of the pendulum with ball. Convert the height change of the pendulum to PE = KE of ball, then to BB velocity.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
