Finding time average Poynting vector
To find the time average of the Poynting vector (N'), given the electric (E) and magnetic (H) fields, one can use the relationship N = E x H. The equation N' = 0.5 * Re{F x I*} is not applicable if E and H are expressed in terms of their real components. Instead, calculating the RMS values of E and B allows for the determination of the average Poynting vector using formulas like S = E B / μ0 or S = E^2 / μ0 c. Time-averaging typically involves the square of sine or cosine functions, which introduces a factor of 0.5. Thus, the correct approach involves using RMS values and understanding the time-averaging process for non-constant fields.
kylie14
Given E and H, obviously you can calculate Poynting vector (N=ExH), but then how do you find the time average of N (N')?
(I won't write all the question I'm trying to answer here but basically I'm trying the verify an equation, the says N' = 0.5* Re{ F x I* } where F and I are fields such that E= Re{F} and H=Re{H}. So obviously I can't use that equation. How else can I find N'?
I memorized those things using B instead of H, but you can convert. Can you write the RMS values of the electric field and magnetic field? You will get the average of the poynting vector S (intensity, or energy per unit time per unit area) if you plug in the RMS values of E and B into any of these:
S = E B / mu0 = E^2 / mu0 c = c B^2 / mu0
Usually vector E and H are made up and constant (eg E0) multiplied by phase and time dependent parts. You must time average these non-constant parts of the equation. Often this comes down to time-averaging the square of sine/cosine, which gives a multiplicative factor of 0.5.
