member 731016
Finding time difference between two arriving wave fronts
- Thread starter member 731016
- Start date
- Tags
- Difference Time Wave
6 replies · 2K views
Discussion
- 16,127
- 9,322
##AB=2R\sin30^o.## Do you see why? Hint: Draw a perpendicular from the center to the base AB. It splits AB into two equal parts. What is the length of each part?
member 731016
Thanks I see it now @kuruman ! Is the reason why they used radians instead of degrees in the arc length formula is because radians is a ratio of the length while degrees is not.kuruman said:##AB=2R\sin30^o.## Do you see why? Hint: Draw a perpendicular from the center to the base AB. It splits AB into two equal parts. What is the length of each part?
Many thanks!
- 16,127
- 9,322
What you call the arc length formula is actually the definition of the angle as the ratio of the arc length to the radius. As such it has no dimensions.
- 42,981
- 10,573
Yes, both are dimensionless in the usual dimensionality system; they just have different units.Callumnc1 said:
That said, many have found this unsatisfactory and have attempted to develop a dimension for angles. If interested, see https://www.physicsforums.com/insights/can-angles-assigned-dimension/
- Breadsticks
- · Replies 5 ·
- Introductory Physics Homework Help
- Replies
- 5
- Ahmed123
- · Replies 7 ·
- Optics
- Replies
- 7
- BigFlorida
- · Replies 2 ·
- Replies
- 2
- Const@ntine
- · Replies 5 ·
- Replies
- 5
- MEGA-DEEN
- · Replies 1 ·
- Replies
- 1
- Rococo
- · Replies 2 ·
- Replies
- 2
- redshift
- · Replies 2 ·
- Replies
- 2
- hemang
- · Replies 9 ·
- Replies
- 9
- mkylman
- · Replies 22 ·
- Replies
- 22
- TheBigDig
- · Replies 6 ·
- Replies
- 6
