Finding total energy as a function of the Fermi Energy
The discussion focuses on calculating the total energy \( U_{total} \) of a gas of spin-1/2 fermions as a function of the Fermi energy \( E_{Fermi} \). The key equation derived is \( U_{total} = \frac{3}{10} \left(\frac{3\pi^2 \hbar^3}{m^{3/2}V}\right)^{2/3} N^{5/3} \), which is established through integration of the density of states \( D(E) \) and the Fermi-Dirac distribution \( N(E)_{FD} \). The integration limits are from 0 to \( E_{Fermi} \), and at absolute zero temperature, the occupational number simplifies to a step function. The discussion emphasizes the importance of correctly applying the equations from the textbook, specifically referencing equations 9-39 and 9-42.
  • Understanding of Fermi-Dirac statistics
  • Familiarity with density of states in quantum mechanics
  • Knowledge of integration techniques in physics
  • Proficiency in using equations related to thermodynamics and statistical mechanics
  • Study the derivation of the density of states \( D(E) \) as given in equation 9-39
  • Learn about the Fermi energy calculation using equation 9-42
  • Explore the implications of absolute zero temperature on particle distributions
  • Practice integrating functions involving the Fermi-Dirac distribution
Students and researchers in physics, particularly those focusing on quantum mechanics, statistical mechanics, and condensed matter physics, will benefit from this discussion.
hb1547
"The numerator of this fraction:
\overline{E}=\frac{\int \! E N(E)D(E)dE}{\int \! N(E)D(E)dE}
(N(E) is the number of particles in an energy state, D(E) is the density of states)
is the total (as opposed to the average particle) energy, which we'll call U_{total} here (In other words, the total system energy U is the average particle energy \overline{E} times the total number of particles N.) Calculate U_{total} as a function of E_{Fermi} and use this to show that the minimum (T=0) energy of a gas of spin-1/2 fermions may be written as:
U_{total}=\frac{3}{10} (\frac{3\pi^2 \hbar^3}{m^{3/2}V})^{2/3} N^{5/3}
- The above.
D(E) = \frac{(2s+1)m^{3/2}V}{\pi^2 \hbar^3 \sqrt{2}}E^{1/2}
N(E)_{FD} = \frac{1}{e^{(E-E_{f})/k_{B}T}+1}
N(E_{F})_{FD} = \frac{1}{2}
\overline{E} = k_{B}T
I'm having a hard time deciding what should be multiplied together, and in which ways.
I thought it would be N(E_{F})_{FD} * \overline{E} (the ones above), yet that obviously isn't a function of E_{Fermi}, it's just a function of temperature.
I guess I'm having a hard time deciding which equations I should be using.
Just finished the same problem. I calculated the total energy using the numerator term in the average energy equation. You can integrate from 0 to E Fermi because T = 0. Then plug in the Fermi energy equation from the book (i'm assuming this is from Harris). It's eqn 9-42. After a lot of cancelation you get the expression given in the book.
Yeah this is the Harris problem haha.
So I plug in the Fermi energy equation for E in the top, as well as N(E)_{FD} and D(E)? Sounds good, I'll try it and see where it gets me. Thanks, I was just leaving the term as E and it wasn't working too well
Hmm actually I'm still having some trouble with this one. I get why you can integrate from 0 to E_{Fermi}, yet I'm not following when you plug in the equation for E_{Fermi}. Did you do it before or after integrating?
If before, I keep getting to an integral I can't solve:
\int_{0}^{E_{F}} \! \frac{E^{1/2}}{e^{(E-E_{F})/k_{b}T}+1} dE
(there are a bunch of constants on the outside as well)
If after, not a lot seems to cancel out -- the integral just becomes more complicated
Remember that in
<br /> \overline{E}=\frac{\int \! E N(E)D(E)dE}{\int \! N(E)D(E)dE}<br />
The numerator represents the total energy. This is what you want to use to calculate it. Your limits are from 0 to Fermi energy. The occupational number (N(E)) turns to 1, because at T = 0 it is a step function equaling to 1 up to the Fermi energy. The density function (D(E)) is given in the book Eqn 9-39. Do not forget to include the E that is not part of the density function. After integrating, you should have total energy in terms of Fermi energy. Now plug in the expression for Fermi energy Eqn 9-42, and simplify.
OH I get it -- that clears it up a lot. Thanks! I was able to get it from there, I really appreciate the help!
  • · Replies 20 ·
  • · Replies 30 ·
