Finding Transition Matrix from Bases
To find the transition matrix from the basis So to S, one must compute the inverse of the matrix formed by the coefficients of the vectors in S expressed in terms of So. The correct matrix to invert is constructed from the coefficients of the vectors u1, u2, u3, and u4. There was confusion regarding the transpose of the matrix, which is not the same as its inverse. Users suggested using online calculators to avoid manual calculation errors due to the complexity of the numbers involved. The discussion emphasizes the importance of verifying calculations to ensure accuracy in obtaining the transition matrix.
concon
Let So = {v1,v2,v3,v4} be a basis of the vector space V.
S= {u1,u2,u3,u4} is a set of vectors defined as follows:
u1 = 80v1 + 106v2 + 120v3 +164v4
u2 = 80v1 + 146v2 + 136v3 + 91v4
u3 = 90v1 + 143v2 + 122v3 + 70v4
u4 = 80v1 + 56v2 + 80v3 + 48v4
Find the Transition Matrix A from the basis So to S. That is find PS->So. This is the transition matrix from S coordinates to So coordinates.
I know that to get from one transition matrix to another transition matrix you can take inverse.
Also, for PS->So I know that means you want to turn So into identity matrix.
I have solved problems like this which small numbers, not equations so I am confused.
I think the easiest way to solve this (this might be wrong) is to find PSo->S and then take inverse. because the equations are in terms of So. So does that mean I take inverse of this matrix:
80 106 120 164
80 146 136 91
90 143 122 70
80 56 80 48
OR
80 80 90 80
106 146 143 56
120 136 122 80
164 91 70 48
-Or is this not even the way to approach this problem? Any advice would be greatly appreciated. Thanks in advance.
Yes.
80 106 120 164
80 146 136 91
90 143 122 70
80 56 80 48
Yes, take the inverse of this matrix. Let's call this matrix A.
concon said:
OR
80 80 90 80
106 146 143 56
120 136 122 80
164 91 70 48
No. What you have here is AT, the transpose of matrix A. You get the transpose of a matrix by writing its rows as columns. For some matrices, the transpose is equal to the inverse, but I doubt that's the case here.
Mark44 said:
Yes.
Okay that's what I thought, just wanted to make sure since when solving something Ax=0 you write the vectors as columns, but I guess here that wouldn't be true since the vector is a multiple of the other vector components.
Well, I took the inverse of matrix A and the answer was not correct.
I got the following as inverse:
\begin{array}{cc}11/2025 & -839/20250 & 11167/324000&2801/288000\\1/270& -16/675&199/5400&-103/4800\\-5/324 & 53/810 & -829/12960 & 253/11520\\1/81 & -1/81 &1/162 & -1/144\end{array}
There's always the possibility that you made a mistake or two along the way. That would prevent your answer from being correct.
Using an online calculator, this is what I got:
$$ \frac 1 {2592000}\begin{bmatrix}14080 & -107392 & 89336 & 25209 \\
9600 & -61440 & 95520 & -55620 \\
-40000 & 169600 & -165800 & 56925 \\
32000 & -32000 & 16000 & -18000 \end{bmatrix}$$
The size of the matrix and the numbers in it make me think that you're not expected to calculate the inverse by hand. Unless you're extremely careful, it's very easy to make a mistake that screws up all the work that follows.
Yes definitely possible I will cross check my answer with yours and see. I also used an online inverse calculator and got my answer that way since doing it by hand could get messy. I'll let you know.
Was the inverse of the matrix A correct? I have a similar problem on my online homework and I have spent countless hours trying to get it right.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
15K
