Finding unitary operator associated with a given Hamiltonian
ubergewehr273
Given a Hamiltonian ##H = \hbar \omega \sigma_1##, you are supposed to find the associated time-evolution unitary operator ##U(t)##.
Time-independent Schrodinger's equation
$$-i \hbar \frac{\partial | \psi (t) \rangle}{\partial t} = \hat{H} | \psi (t) \rangle$$
The associated unitary operator is
$$U(t) = \exp (\frac{-i \hat{H} t}{\hbar})$$
Now from the relevant equations,
$$U(t) = \exp(-i \omega \sigma_1 t)$$
which is easy to compute provided the Hamiltonian is diagonalized. Writing ##\sigma_1## in its eigenbasis, we get
$$\sigma_1 =
\begin{pmatrix}
1 & 0\\
0 & -1\\
\end{pmatrix}
and hence the unitary ##U(t)## becomes
$$U(t) =
\begin{pmatrix}
e^{-i \omega t} & 0\\
0 & e^{i \omega t}\\
\end{pmatrix}
Mind you that the above representation of $U(t)$ is in the basis ##\{ |+\rangle, |-\rangle\}## where
$$ |+\rangle =
\frac{1}{\sqrt{2}}
\begin{pmatrix}
1\\
1\\
\end{pmatrix}
$$ |-\rangle =
\frac{1}{\sqrt{2}}
\begin{pmatrix}
1\\
-1\\
\end{pmatrix}
Now, I need to write ##U(t)## back in the original basis ##\{|0\rangle, |1\rangle\}## (which is where I'm facing an issue). Finding the components of the above expression for ##U(t)## in the original basis,
$$\langle 0 | U(t) | 0 \rangle = e^{-i \omega t} \qquad \langle 1 | U(t) | 1 \rangle = e^{i \omega t}$$
with ##\langle 0 | U(t) | 1 \rangle = 0## and ##\langle 1 | U(t) | 0 \rangle = 0##. This gives me the exact same matrix representation in the original basis. Obviously this is not true and I'm doing something wrong.
You'll have to show your work, for instance ##\langle 0 | U(t) | 0 \rangle##, because the result you get is incorrect.
You can write your solution in terms of
$$\hat{U}=\exp(-\mathrm{i} \omega t) |+ \rangle \langle +| + \exp(\mathrm{i} \omega t) |- \rangle \langle -|.$$
Now simply express ##|+ \rangle## and ##|- \rangle## as linear combinations of ##|1 \rangle## and ##|0 \rangle## and multiply out the dyadic products. Then you can read out the matrix elements easily.
A much easier way is to directly use the properties of the Pauli matrix. All you need is ##\hat{\sigma}_1^2=1## and then write down the power series for the exponential function.
