Finding unknown velocity and time from distance and accelerations
19 replies · 4K views · last reply
chiraganand
the problem goes like this
YOu are asked to start from rest, go a distance L=105 m and end up at rest again all in minimum time. Your vehicle has a maximum acceleration of a1 and maximum braking of a2. Determint t1, t2 and maximum speed. a1=7.5m/s^2 , a2=-10 m/s^2. The plot of acceleration versus time is attached
I have attempted the solution using the veocity equations but i have 3 unknows the velocity and the times. Tried deriving an expression for accelertionand elocity but not getting it. stuck how to go ahead. Please help
  • Acceleration versus time plot: a1 is a horizontal segment above the time axis, a2 a lower segment below it, with t1 and t2 marked along the time axis, and a middle segment spanning t1 to t2.
Show us what you did so far, please.
till t1 i found the velocity as 7.5t1 and from t1 to t2 the velocity as -10 (t2-t1). I don't know how to go ahead from this
For the case of constant acceleration, do you know the basic algebraic equations for velocity and distance as a function of time, given the initial velocity v0 and the initial distance x0? Do you know the relationship between velocity and distance (without time in the equation) for the case of constant acceleration? Please write these equations down for us. These will be the equations that you will be working with.
Chet
for constant acceleration, velocity and time is given by v2=v1+at and velocity and distance is given by v2^2=v1^2+2as where s is displacement
Good. Ok. The one other equation I'd like to see is distance versus time. Question before we begin: Is that 105 m the distance covered during t1, or is it the total distance covered from start to stop?
Chet
Well that is what I qm confused about... because what I have posted is exactly the question that I have. .. not able to figure out if its total distance or not
Of course, it wouldn't be too complicated to do it both ways. Let's first try the version where it's the total distance. Let x = distance traveled during t1 and let (105 - x) = distance traveled during t2.
Let's first focus on the time interval t1. If a1 is the acceleration during this time interval, how long does it take (t1) for the vehicle to travel from rest at x = 0 to the location x? What is it's velocity when it reaches x?
Chet
Velocity at t1 will be either in terms of t1 or distance x
V(t1)^2=2a1x
V(t1)=a1t1
V(t1)^2=2a1x
V(t1)=a1t1
What is t1 in terms of a and x?
What is V(t1) in terms of a and x?
chiraganand said:
T1 wud be sqrt of x/a1
Actually, it would be
[tex]t_1=\sqrt{\frac{2x}{a_1}}[/tex]
The velocity at the end of t1 would be
[tex]v(t_1)=a_1t_1=\sqrt{2a_1x}[/tex]
Does this make sense so far? If so, we are ready to start the time interval t2.
Yep it does... fot the interval t2 the time will be t2-t1 right
Not really. We are starting the second half of the problem, and we need to use the equation:
[tex]s=s_0+v_0t+\frac{1}{2}a_2t^2[/tex]
For this time interval, s0=x and [itex]v_0=\sqrt{2a_1t_1}[/itex] where we restart the clock at the end of t1 to t = 0. Also, the velocity during this time interval is given by: v=v0+a2t
So, when t = t2, v = 0 and s = 105. Substitute these values into the above equations and solve for t2 and then x.
chiraganand said:
But I am getting two unknows now.. t2 and x
Yes, but you have two equations. Solve the velocity equation for t2 in terms of x, and then substitute that into the displacement equation.
Chet
Still not able to get it...seems to be easy but not getting it
[itex]v_0=\sqrt{2a_1t_1}[/itex] and 0 = v0+a2t2.
1. Solve for t2
2. Substitute into 105 = v0t2+0.5a2(t2)2
3. Solve for x
