Finding work from force vector (2.7i + 3.2j) N and displacement
  • Thread starter Thread starter silentsaber
    Vectors Work
silentsaber
A force F = (2.7i + 3.2j) N is acting on a particle while it travels from the point (x, y) =
(1, -1) m to the point (2, 1) m. Find the work done by the force F on the particle.
W=FD and A=SqRt of Ax^2+Ay^2
ok i used the right triangle to find the resultant vector of the force F by squaring both the 2.7 and 3.2 then adding them and take the square root i got 4.18 so that should be the F in W=FD and then i foudn the reultant vector of the coordinates 1,-1 and 2,1 and got square root of 5. which should be the distance and then i multiplied 4.18 and radical 5 and got 9.34 which is wrong.. where did i go wrong? btw 9.10 is the answer
Hi silentsaber,
The problem is that the formula for work is not [itex]W=Fd[/itex] (product of magnitudes of force and displacement), it is
[tex]W=\vec F\cdot\vec d[/tex]
(dot product of force and displacement vectors). Are you familiar with the dot product? If so, then once you find the two vectors involved the problem is quite straightforward.
You're working with vectors. So you need to find the dot product. W = F dot D.
thankyou guys very much i totally forgot the dot product existed XD
