Finding X, Y in complex numbers.
The discussion revolves around solving the equation 8i = (2x + i)(2y + i) + 1 for complex numbers x and y. The initial solution presented yields x = 0 and y = 4, which is confirmed as correct by the student after consulting their teacher. However, there is a second solution, x = 4 and y = 0, that also satisfies the equation, highlighting the symmetry in the problem. The conversation emphasizes the importance of considering both solutions rather than concluding with just one. Ultimately, both pairs of values are valid solutions to the equation.
TheKittehCP
8i = ( 2x + i ) (2y + i ) + 1
The final answers is [x =0, 4]
[y=4, 0]
The final answer in the book is stated as above but if I follow the solution I will get the real parts which would
Equal 0=4xy meaning that both x and y when solving for either wil equal zero. If I continue the result I will get is
[X= 0, Y= 4]
I get one solution instead of 2 as provided in the book..
x=0 and y=4 is indeed one solution. There is another one and it's very similar to the first. Hint: note the symmetry of the real and imaginary equations in terms of x and y!
I don't see your attempt at a solution...?
If you are given number = a *b +another number, then it is obvious that number - another number = a*b
In the case of complex numbers, if we call the Real part of x, Re(x), and Im(x) for the imaginary part so that x = Re(x)+Im(x), then it is straightforward that:
Re(number-another number) = Re((2x+i)(2y+i)) and
Im(number-another number) = Im((2x+i)(2y+i)) and
this gives you two equations and two unknowns.
OK, how did you arrive at x=0, y=4? (Your post 1). Show every step.
x and y are real numbers.
My answers X=0 and Y=4 were correct, I talked to the teacher and he said the final answers given were wrong
Here's how I came up with it:
8i = 4xy + 2xi + 2yi + i^2 + 1
0 + 8i = 4xy + 2xi + 2yi -1 + 1 [ Since i^2 equals -1 ]
Real part = real part thus
0=4xy
X = 0/4y
X=0
Imaginary part = imaginary part thus
8 =2x + 2y
-2y = 2x -8
2y = 8-2x
Y = (8-2x)/2.. Now substitute with X=0
Y = (8-0)/2
Y= 4
[ X= 0, Y=4]
This is the correct solution. Thanks for the help everyone ^^
0=4xy
X = 0/4y
X=0
##4xy=0## means either ##x=0## or ##y=0##. You only have one of the two answers.
8 =2x + 2y
-2y = 2x -8
2y = 8-2x
Y = (8-0)/2
Y= 4
[ X= 0, Y=4]This is the correct solution. Thanks for the help everyone ^^
It is an incomplete solution. ##x=4,~y=0## also works as suggested in post #2.
Looks like LC did the rest for you. It is correct. If your teacher said the two answers are wrong then HE is wrong.
I also did that when I didn't get the answer same as mine but I think the difference is that X doesn't equal 0 and 4 in the same formation; X either equals 0 or 4 depends on what you solve for.. It doesn't equal 0 and 4 when we solve for the same variant such as
x (x-4)=0
Where X will equal both 0 and 4 and get final answer as [x = 0, 4] instead of [x =0] only or [x=4] only.. I talked to the teacher about the possibility of when X equals 0
When we solve for x at 4xy = 0 and when it equals 4 when we solve for Y at the same part and he said they're both correct.8
  • · Replies 42 ·
  • · Replies 18 ·
  • · Replies 47 ·
